February 12, 2026, 07:31:57 PM *
Author Topic: Switched 12 v power source  (Read 1310 times)
Chuckman
« on: July 17, 2021, 08:42:18 PM »
I have been trying to connect LED accent lights, but am having trouble locating a switched power source.
Any pics or diagrams anyone could share?
Timbo1
Tulsa, Ok.
« Reply #1 on: July 17, 2021, 09:29:07 PM »
Switched power source usually is referring to ac to dc switching power supply.  If connecting to a 12V system like an auto or bike that's not needed.
« Reply #2 on: July 17, 2021, 10:17:29 PM »
I think he means a power source that is energized with the key. There is an accessory circuit under the right side panel. It is only 5 amp though. If your led’s need more than that you can use it as a trigger with a relay.
RonW
Newport Beach
« Reply #3 on: July 17, 2021, 10:19:35 PM »
he means a key-on wire that only has electricity when the key in the ON position.
Under right side cover, there's an empty +12 ACC plug (arrow) under the rubber boot X. The secondary plug is Ground. Like said, only 5amps.
Chuckman, can you post a pic of the same section?
« Last Edit: July 17, 2021, 10:37:30 PM by RonW » Logged
2000 Valkyrie Tourer
Chuckman
« Reply #4 on: July 18, 2021, 10:09:13 AM »
Got it!
Hooked up and working perfectly!
Thanks everyone!
