April 29, 2026, 09:07:35 AM *
Author Topic: Vibration  (Read 4826 times)
PuyallupValk
« on: July 28, 2021, 03:18:57 PM »
Hello! I’ve got 99 Interstate with 56k miles. The other day I noticed a fairly substantial vibration at highway speeds under throttle…any throttle. It goes away completely when i get off throttle. Based on what I’ve read, it seems like the u-joint may have gone bad, but I’d like some opinions from you guys!
I’d also like to meet up with someone to swap bikes with just for a quick jaunt to see if my bike has any other abnormal sounds/issues. This is my first Valk and a total departure from anything else I’ve had so I’m not 100% sure of what ‘normal’ is.
I’m located in Puyallup but will travel, of course…lol.
Thanks!
Mike Parker
509-302-9897
« Reply #1 on: July 28, 2021, 03:51:00 PM »
A bad Ujoint usually ends up thumping on the footpegs and making squeaking, screeching or grinding noises... more than a vibration.
I was able to minimize (not stop) mine by going about 35mph to make it far enough to get to work on it.  It wasn't related to throttle, it was speed; over 35 got worse in the thumping and grinding.
Put it on the lift and do some investigating.
Possibly the tire or shock bushings?
« Reply #2 on: July 28, 2021, 04:48:21 PM »
It could be the u-joint starting to go bad. It could just as likely (maybe more likely) be a tire.
PuyallupValk
« Reply #3 on: July 28, 2021, 09:40:48 PM »
Thanks for the replies, gents. This doesn't feel like a tire...and it only happens under throttle at higher (45mph+) speeds...goes completely smooth off throttle...
« Reply #4 on: July 28, 2021, 09:48:36 PM »
I once had the same thing. I was sure it was the u-joint going bad. After a new u-joint, no difference. Pulled the Shinko front tire, and it went away. Couldn’t tell or see anything wrong with it, but it was definitely the tire.
PuyallupValk
« Reply #5 on: July 29, 2021, 06:41:14 AM »
I'll definitely take a look!
