February 12, 2026, 05:57:32 PM *
Author Topic: A really dumb question about Daymaker lights  (Read 1198 times)
Bagger John - #3785
« on: August 03, 2021, 09:56:27 AM »
Which set of elements should normally be active when on Low beam, and which on High?
I've a standard type here: Small projector lens in the upper half of the light; larger one in the lower and two sets of sidelights arranged vertically on either side of the projectors.
Both projectors come on when running on Low beam; they go off and the sidelights come on when running High beam. The issue is...High beam appears to be aimed lower than Low.
Have to try this thing out at dark, but I don't want to blind oncoming traffic.
Bagger John - #3785
« Reply #1 on: August 04, 2021, 06:37:02 AM »
An answer, for those who use the projector-style lights:
Look closely for the "Up" ( ^ ) arrow on the lens. The DOT certification lettering is on the opposite side of the light and should be on the bottom when the light is mounted.
What threw me is the arrangement of the projector setup. A lot of these lights have the small lens at the top, with the larger at the bottom of the assembly. Mine was exactly bass-ackwards and that;s how I installed the unit in my headlamp shell.  uglystupid2
Standardization is nice when everyone does it. The way I had mine mounted resulted in my low beam being in the trees. Of course, one had to wait until after dark to discover this....
CoreyP
Bluffton, SC
« Reply #2 on: August 04, 2021, 10:01:48 PM »
LOL, now you know.
