yrunvs
« on: August 04, 2021, 04:15:16 AM » |
So I'm cruising down the road and I glance down and for the first time I notice that the cylinder head covers are not asymmetrical, that is to say the right side sits farther forward then the left side (or at least appears to). I measured from the rear of my right cylinder head to the right foot peg then I took the same measurement on the left side and there is at least one inch difference, the right having more distance. The left and right cylinder head covers measure the same size and everything appears square and nothing looks cocked. The timing belt housing is thicker on the left side than the right side but still?. Is my engine in the frame wrong? is there an explanation for this? or am I just stupid?
« Last Edit: August 04, 2021, 04:28:34 AM by yrunvs »
I'm no gynecologist but hey I'll take a look!
Doug B.
« Reply #1 on: August 04, 2021, 04:25:42 AM » |
You need the offset to accommodate the connection of multiple connecting rods to a single crank.
pancho
« Reply #2 on: August 04, 2021, 04:26:10 AM » |
That is the way it is supposed to be, the rods from one bank need to set in front of the rods from the other on the crankshaft, so a bit of axial offset from one side to the other.
Don't freak out.
yrunvs
« Reply #3 on: August 04, 2021, 04:32:14 AM » |
I'm surprised I never noticed this before.
« Reply #4 on: August 04, 2021, 05:41:51 AM » |
It still makes me a bit cross eyed when looking at the engine from the seat or from the front to see the difference in protrusion each side.
Bagger John - #3785
« Reply #5 on: August 04, 2021, 06:29:00 AM » |
...the cylinder head covers are not asymmetrical, that is to say the right side sits farther forward then the left side (or at least appears to). I
If they're offset relative to each other, they are in fact "asymmetrical".
pancho
« Reply #6 on: August 04, 2021, 07:21:09 AM » |
I'm not..... you probably have many going out looking at their Valks right now.
RonW
« Reply #7 on: August 04, 2021, 07:29:07 AM » |
The timing belt cover is also offset to match the Left cylinder bank offset. Like yrunvs stated about 1-inch.
« Last Edit: August 04, 2021, 07:30:46 AM by RonW »
2000 Valkyrie Tourer
Mooskee
« Reply #8 on: August 04, 2021, 07:31:16 AM » |
https://images.app.goo.gl/Ug71VDkngrgLGXcV7Here is a diagram showing the connecting rod connections to the crank shaft. The opposing rods and thus the pistons have to be offset to connect to the crank shaft. Since the pistons are offset, the piston heads are offset, and the head covers are offset. Ride safe.
« Reply #9 on: August 04, 2021, 10:34:17 AM » |
I never really noticed it until adjusting my highway pegs years ago. I adjusted the the angles to match each other and found one was a longer stretch than the other.
yrunvs
« Reply #10 on: August 04, 2021, 12:32:16 PM » |
Actually that is what got my curiosity up. I was trying to figure out why my highway pegs felt different side from side.
CoreyP
« Reply #11 on: August 04, 2021, 10:05:04 PM » |
Same here. I was like, what is going on here they aren't the same. Took a little while to figure it out.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #12 on: August 05, 2021, 06:47:23 AM » |
If you REALLY want to see offset, look at a BMW opposed twin ("R" bike). The cylinders are way offset as well as the footpegs. Almost no one notices that either.
h13man
Indiana NW Central Flatlands
« Reply #13 on: August 05, 2021, 06:57:40 AM » |
I measured from the engine guards for placement for the pegs but just didn't care for them being in the way if a drop were to happen and the valve covers being the recipient of the the pegs folding into them.
Bagger John - #3785
« Reply #14 on: August 05, 2021, 08:58:29 AM » |
Primarily marketed to ridge runners, who will understand the joke.
WintrSol
« Reply #15 on: August 05, 2021, 10:59:24 AM » |
Primarily marketed to ridge runners, who will understand the joke.  Especially after a jug of that Kickapoo Joy Juice.
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
