February 12, 2026, 05:57:37 PM *
Author Topic: Front wheel squeal  (Read 1328 times)
Vman986
« on: August 07, 2021, 06:44:53 AM »
Just started today. Only at full tight turns, like a U turn, front wheel squeals at a high pitch as the wheel turns. Doesn’t do it on regular curves or turns. Would that indicate axle dryness or wheel bearing? Thanks fro any help in advance.
Bagger John - #3785
« Reply #1 on: August 07, 2021, 06:53:35 AM »
Wheel bearing, most likely.
Once tightened during installation, the axle shouldn't come into play whatsoever other than to support the rotating assembly (the wheel).
Savage
United States
« Reply #2 on: August 07, 2021, 08:13:33 AM »
Yup, sounds like front wheel bearing.
Probably best to just change both of them at the same time.
Fortunately, the job is WAY less involved than the rear wheel.
Columbia, South Carolina
« Reply #3 on: August 07, 2021, 08:23:45 AM »
Up on the lift, funny noises can sometimes be replicated and sourced.
Try spinning the wheel at full right lock.
Jims99
Ormond Beach Fl.
« Reply #4 on: August 07, 2021, 10:09:49 AM »
Could you be pinching a brake line at full turn causing the brake to squeak? Just a thought.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Icelander
Snohomish, WA
« Reply #5 on: August 07, 2021, 08:08:05 PM »
I replaced my brake pads a few years ago and get a squeal out of them at walking speed while I'm maneuvering my bike into her parking spot. Sure you're not hearing the pad fall against the rotor?
I put new bearings on my wheels every time I replace my tire. (Got a spare set of wheels so she's not down while I get around to mounting the new ones.)
Hope you find the noise and fix it.
Kendall
1998 Valkyrie Tourer.
VRCC Member #36337
turtle254
Livingston,Texas
« Reply #6 on: August 08, 2021, 08:12:45 AM »
Kendall
Whats the wheel bearing numbers?
turtle254
Livingston,Texas
« Reply #7 on: August 09, 2021, 07:38:18 AM »
just order them, hope this is right!
5204ZZBearing   5204ZZ Bearing Angular contact 5204ZZ
   2   $19.49   $38.98
6204ZZBearing   6204ZZ Bearing Deep Groove 6204ZZ
   2   $5.55   $11.10
98 std
« Last Edit: August 09, 2021, 09:37:47 AM by turtle254 » Logged
Bagger John - #3785
« Reply #8 on: August 09, 2021, 07:45:09 AM »
   2   $19.49   $38.98
   2   $5.55   $11.10
First, ask the OP what year bike - and check the bearing pocket diameters. 97s used 42MM OD while all others use 47MM.
CoreyP
Bluffton, SC
« Reply #9 on: August 09, 2021, 08:20:06 PM »
I had an odd noise in tight turns which turned out to be a frozen caliper later on. I knew something wasn't right but the wheel bearings worked fine so???? One day the front brakes just kind of froze up on me. Lucky I was like a mile from my house so I just rode it home with the brakes dragging. I had a terrible time getting the one piston out, it just wouldn't move.
My first guess would be wheel bearings.
