December 29, 2025, 07:48:22 PM
Pilot Screw Needle Broken
Topic: Pilot Screw Needle Broken (Read 1478 times)
JimF2424
Valkyrie
Gulfport MS
August 07, 2021, 05:31:39 PM »
Had a hydrolock in #2, believe it was a stuck float, removed the carburators, #3 Pilot screw full of corrosion, #4 pilot screw needle broke off and is inside the carb. Does anyone know a way to remove the needle. I'm thinking of a small drill bit and do it by hand, twisting back and forth. Surprise that the bike was running as good as it was.
Re: Pilot Screw Needle Broken
August 07, 2021, 05:54:16 PM »
There was someone recently that did that, then a tiny drop of super glue in the drill bit to remove it.
I think you will have to have a very steady hand, a lot of patience, and good eyesight to pull it off though. (I wouldn’t stand a chance)
DeathWishBikerDude
August 07, 2021, 06:14:29 PM »
https://youtu.be/J8gXnaJr2J0
Bagger John - #3785
August 07, 2021, 08:02:08 PM »
Attic Rat volunteered a carb body to the member in question before the broken part was successfully removed. Might check with him and see if he can help.
JimF2424
Valkyrie
Gulfport MS
August 08, 2021, 05:56:47 AM »
Thanks for the suggestions, I'm going to try the Glue, that sounds like it might work.
JimF2424
Valkyrie
Gulfport MS
August 08, 2021, 05:59:22 AM »
I've been watching D-Ray's video's on YouTube, he's very good, and good quality video's, there great help.
JimF2424
Valkyrie
Gulfport MS
Reply #6 on:
August 08, 2021, 03:24:49 PM »
Found a Mechanic that rebuilds Valkyrie Carbs, going to let them handle it.
https://www.valkyrieflatsix.com/services
=> InZane XXV
