February 12, 2026, 07:33:15 PM *
Author Topic: Need longer throttle cables - Honda Valkyrie std.  (Read 2429 times)
Pchenry
« on: August 10, 2021, 02:13:34 PM »
Hi
I changed raisers for my short arms  Wink
Now I need throttle cables that is 5-10 cm longer. Anyone who knows where to order.
I checked Motion Pro, but they dont ship outside US. I live in Norway.
Thanks in advance.
-Henry-
Bagger John - #3785
« Reply #1 on: August 10, 2021, 02:20:46 PM »
Check with Russell or Galfer and see if they make custom cables.
Ken aka Oil Burner
Mendon, MA
« Reply #2 on: August 10, 2021, 04:01:31 PM »
Hi Henry.
I commented on your FB post about trying Barnett. They made me some years ago with no issues, but then again, I live in the US, so shipping to me was no problem.
Bigwolf
Cookeville, TN
« Reply #3 on: August 10, 2021, 04:09:34 PM »
Have you tried running the original cables behind the triple tree and over the top of the frame neck then down beside the air box?
I have 5 1/2 inch risers with 1 inch pull back.  I have the stock OEM cables routed behind the triple tree and over the top of the frame then down beside the air box and it works quite well for me.
Bigwolf
Pchenry
« Reply #4 on: August 11, 2021, 10:44:32 AM »
Hi Henry.
Hi
I have sent them an email. Thanks Smiley
Bagger John - #3785
« Reply #5 on: August 11, 2021, 11:47:23 AM »
Check this outfit out too: https://www.motionpro.com/c/custom-cables
6adan
Zip City, Alabama
« Reply #6 on: August 12, 2021, 09:09:46 PM »
  You can also use a starter switch from a interstate which runs the cables down instead of out the front which worked for me when I put higher risers on mine.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
Bagger John - #3785
« Reply #7 on: August 13, 2021, 06:44:27 AM »
+1
