February 12, 2026, 05:58:19 PM *
Author Topic: Break light  (Read 1374 times)
Grey wolf oz
« on: August 14, 2021, 06:17:54 PM »
Guys
Along with pulling the top box,
Any ideas on what break light from Honda models that fit the Valkyrie
I have fitted a standard small one as a short term
Again getting parts local that fit valkyrie specifically is tricky
« Reply #1 on: August 14, 2021, 07:29:48 PM »
The BRAKE light is the same on the shadow Ace I believe.
RonW
Newport Beach
« Reply #2 on: August 14, 2021, 08:37:21 PM »
You might need a Valk's rubber gasket ($16.25) since the Valk has a huge cavity molded in the rear fender for the tail light. The Shadow Ace 1100's gasket has just an outline shape that's designed to seal aroung the edge.
2000 Valkyrie Tourer
« Reply #3 on: August 14, 2021, 09:46:03 PM »
The word is that a couple other Hondas (including the Shadow Ace) use the same tail light as the Valk, but the mount plate is supposedly not a quite right fit for the fender cutout.  I think they use the same lens. They have been made to fit and work, but I don't know any more detail.
If you will access Honda tail light parts fishes for Valk and others, you can compare part numbers.
Valk (all years)
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/GL1500CA_(99)_VALKYRIE%2c_USA%2c_VIN%23_1HFSC340-XA200001/TAILLIGHT/4a380688-44e5-4f7d-9a7d-1f19c6a1fb1b/2014a224-6918-4a83-bafd-e46ac3919148/y
Edited to correct 1100
SHADOW SABRE 1100 VT1100C2A (03)
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/VT1100C2A_(03)_SHADOW_SABRE%2c_USA%2c_VIN%23_1HFSC430-3A300001_TO_1HFSC430-3A399999/TAILLIGHT/a49136fc-d558-42ac-a110-00d018748df7/c39ba1d8-713e-4bd7-ae78-95f0fc73b0b6/y
« Last Edit: August 15, 2021, 04:42:50 AM by Jess from VA » Logged
RonW
Newport Beach
« Reply #4 on: August 14, 2021, 11:19:41 PM »
  • but the mount plate is supposedly not a quite right fit for the fender cutout.
the Valk tail light has threaded inserts (internal threads), while the other options have a plate with male screws. It's a do they line up question?
« Last Edit: August 14, 2021, 11:21:15 PM by RonW » Logged
Grey wolf oz
« Reply #5 on: August 15, 2021, 01:36:44 AM »
Thank you every one for the replies
Luke
« Reply #6 on: August 15, 2021, 06:23:48 AM »
BTW if you get the Radiantz multiple LED tailight for the Valk, it's directional alignment isn't right for the angle the fixture sits.  I was able to adjust it almost correctly, I think with a Dremel.  A bit disappointing considering the price over $100.  But it is very bright especially on braking and won't burn out.  Incidentally, I have found when LED's do fail it's always the connections.  Careful work with a soldering iron fixes them.
« Reply #7 on: August 15, 2021, 06:40:58 AM »
My old Radiantz led array in taillight has about a half dozen leds out.
I don't care.
I will say, an led array under an interstate trunk (shade) is brighter than in sunlight.
Grey wolf oz
« Reply #8 on: August 15, 2021, 04:20:58 PM »
Thanks guys !
