January 30, 2026, 06:32:12 AM *
Author Topic: Welding question - Piggies want to be long again.  (Read 2399 times)
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« on: January 09, 2010, 09:26:47 PM »
Hi all,
My 99 Interstate has the three 'piggies' in each exhaust pipe cut back to about 1.5".
I am wanting to lengthen them. I have noticed that 3/4" copper plumbing fittings slip right over the steel pipes.
My question is , can these be successfully bonded through soldering, like with plumbing? Or is there an epoxy or something that can be used to bond two Copper and Iron/Steel.
Best regards,
Glenn
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
T-Bird
Cleveland, Tennessee
« Reply #1 on: January 09, 2010, 11:35:08 PM »
yes...you can weld with a wire-feed welder, or you can solder or braze using a flux.
PharmBoy
Lawton, Ok
« Reply #2 on: January 10, 2010, 06:03:34 AM »
I performed this operation on my '99 I/S just before installing the truck stacks and I am totally satisfied with the results...JTL  Grin Grin Grin
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
sugerbear
wentzville mo
« Reply #3 on: January 10, 2010, 07:37:30 AM »
i used a set screw in each one. worked fine for me.
GJS
« Reply #4 on: January 10, 2010, 09:49:27 AM »
Very cool.
Thanks for the pictures PharmBoy!
I'll do this later today.
Thanks guys,
Glenn
- W. M. Lewis
« Reply #5 on: January 10, 2010, 02:54:27 PM »
Jim,, you must be showing your age.. An experienced [ I won't say old] aviator like yourself quieting a motorcycle ??  I'm shocked !!
PharmBoy
Lawton, Ok
« Reply #6 on: January 11, 2010, 07:47:21 AM »
Patrick, I'm getting hard of hearing.  Too many center-fire & shotgun shells fired, too many hours of running outboard engines, too many hours straddling a two stroke, and too many hours in those noisy old airplanes.  However, I'll gladly learn to live with a little hearing loss for all the thrills and the memories...JTL Grin Grin Grin
99 Interstate
97 Bumble Bee
97 Red & White
