February 12, 2026, 05:58:17 PM
Another vacuum question
Topic: Another vacuum question (Read 1368 times)
GL15Brewer
Wherever I may roam
August 28, 2021, 11:32:48 AM »
So still having issues with top end power. I still haven't synced the carbs since rebuild, issues building the manometer. I did notice that the hose I replaced on the air cut valves may be slightly too big. Could this be the final vacuum issue I need to resolve? Would this cause a lack of top end power?
da prez
Wilmot Wi
Re: Another vacuum question
August 28, 2021, 12:42:22 PM »
Vacuum hoses need to be tight. Not all hoses are vacuum capable. If not desmogged , it would be a good idea.
da prez
Mooskee
Southport NC
August 29, 2021, 07:16:42 AM »
Order the correct air cut valve vacuum hose from Redeye. If it leaks it is causing a problem. Find someone with a Digi sync in your area, and properly sync the carbs.
Last Edit: August 29, 2021, 10:24:07 AM by Mooskee
Valkyrie Carbs and Custom
www.valkyriecarbsandcustom.com
