February 12, 2026, 07:32:33 PM *
Author Topic: 97 rear wheel play  (Read 1322 times)
lostparrot
Northern IL
« on: August 29, 2021, 12:18:30 AM »
So, when I have my rear wheel off the ground and in gear, there is a considerable amount of forward and back movement. When I'm at highway speeds, I can feel a slight thump when I let off the gas, and when I get back on it. I put a new tyre on this spring and everything looked fine. I was wondering how much movement the rear wheel has when in gear?
RonW
Newport Beach
« Reply #1 on: August 29, 2021, 04:18:48 AM »
Never heard of that much movement, but somebody else might have.
The "thump" when you let off the gas sounds like it's something with the kush drive's rubber dampers. But worn rubber dampers wouldn't cause that much movement you described with the wheel off the ground. Was tempted to say it's the propellor shaft or U-joint but since the rear axle pegs the left side of the rear wheel in place, I dunno. Swingarm bearings? Did you torque the rear axle to specs?
« Last Edit: August 29, 2021, 04:24:34 AM by RonW » Logged
2000 Valkyrie Tourer
« Reply #2 on: August 29, 2021, 05:39:12 AM »
It is probably worn dampers.  I assume what you are describing, "a considerable amount of forward and back movement" is movement in the wheel.  This would not be swingarm bearings.
RonW
Newport Beach
« Reply #3 on: August 29, 2021, 06:40:37 AM »
okay I'll go strike out swingarm bearings.
« Reply #4 on: August 29, 2021, 07:52:56 AM »
If you serviced the pinion cup and those splines were good then that leaves dampeners or u-joint. Either way I would avoid hard acceleration until you get it sorted out.
Avanti
Stoughton, Wisconsin
« Reply #5 on: August 29, 2021, 11:21:27 AM »
It is possible to pull the drive boot back and inspect the u-joint with the transmission in gear and rear wheel off the ground.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #6 on: August 29, 2021, 12:15:24 PM »
When you say that there is a lot of fore and aft movement when the wheel is rotated, what are you comparing that too. There are a number of gears between the crankshaft and the u-joint, each with a small amount of gear clearance. it will never be 'tight'.
« Last Edit: August 30, 2021, 02:54:27 PM by indybobm » Logged
So many roads, so little time
VRCC # 5258
Rio Wil
« Reply #7 on: August 29, 2021, 01:10:46 PM »
As I remember, there is about 1 1/2 inch rotation play in first gear. The higher you go up in gears the less the play becomes, but it will not be completely play free.....to many gears in involved and then add whatever pla loose dampers might add.
