I'm in need of at least 5' minimum of stranded wire(prefer more if available), no larger than 20 gauge, and needs to be purple with a white stripe. Every place I look there's a minimum order involved, plus not in the color needed to match existing wiring. Any suggestions as to where to look?
I have a short piece of white/purple(color reversed) I'm tempted to use. It's not long enough but since it will be in a wire wrap I'm debating using a short piece at the beginning and at the end with an available odd color in the middle to make the run. That way at least the visible colors would match although reversed. And, in using the metric bullet connectors in attaching the module I'm working with, I can make this one connection a male as compared to the others which are all female. At least you would have no option but to make that hook up since no other connections would work at that station. I'm close to being done and this is my big stumbling block...so far at least.
