January 30, 2026, 06:32:08 AM *
Author Topic: Tilting the I/S fairing/windshield.  (Read 2333 times)
2qmedic
Simply Awesome!!!
« on: January 10, 2010, 03:58:26 PM »
I have read of tilting an I/S fairing/windshield by placing a 1 inch spacer at the lower mounting point, what were the results?
sugerbear
wentzville mo
« Reply #1 on: January 11, 2010, 07:08:35 AM »
i THINK that was for the standard and tourer only. i have been wrong MANY time in the past.
so ymma
would like to tilt my i/s also but don't see how either.
2qmedic
Simply Awesome!!!
« Reply #2 on: January 11, 2010, 07:32:05 PM »
This is what I have read regarding tilting the fairing.
Take the back side of the fairing off on each side (approx 6 screws each side).
Look under the fairing, you will see a bolt slightly forward of the fork holding the lower mounting point of the fairing. Remove the bolts (one on each side).
Tilt the fairing back slighty to create approx a 1 inch space. A piece of medal with two holes, 1 inch on center, can be bolted to the orignal mount and then to the fairing mounting point. Of course the head lights will have to be readjusted.
This as I understand, actually allows the air turbulance to be lifted a little highter because the angle af attack is a little more stream lined.
Makes sense but before I do this, I was wanting some input from someone whom has actually tried this.
Hopefully some one will see this post share their experience.
sugerbear
wentzville mo
« Reply #3 on: January 12, 2010, 07:37:23 PM »
wouldn't that result in a huge adj of the headlights?
will they adj that far?
2qmedic
Simply Awesome!!!
« Reply #4 on: January 12, 2010, 07:48:30 PM »
There is alot of adjustment latitude on those headlights.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #5 on: January 12, 2010, 07:55:14 PM »
  One of our members here in Des Moines triked his I/S and added a raked tree.  He had to tip his fairing because he couldn't get the headlights adjusted properly.  I believe he tipped it forward because he said his headlights were shining on overhead signs on the highway.
States I Have Ridden In
