February 12, 2026, 05:58:20 PM *
Author Topic: No Headlight!  (Read 2209 times)
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« on: September 02, 2021, 11:48:08 AM »
Bike starts and all the other lights work including the horn, but not the headlight!
Here's the story...
Went to go for a ride and started through my check list...
Start the motor:
right blinker -- check;
left blinker -- check;
brake light front brake -- check;
brake light rear brake -- check;
hi-beam/low-beam -- nothin';
horn -- check;
...wait...hi beam/low beam - nothin'!!
Holy cow, no headlight!
Maybe the fancy new LED is no good?  Maybe it's a fuse?  (If it's the fuse, then why would it blow?) Could it be the hi beam indicator bulb is out?
Nope
After checking the shop manual's wiring schematic the hi beam indicator light being out would not keep the headlight from working.
Opened the headlight housing and put in a checked out halogen bulb...nothing!  It's gotta be the fuse...
But first, wiggle the starter switch...BAM!  Headlight on!
Sooo...I got to clean/rebuild the starter switch!
Here's some pics...
https://drive.google.com/drive/folders/1GkW4hl-riForlbK_Xm8ldqTXzruYRsGe?usp=sharing
As most folks on this site know, all you need for this simple maintenance procedure is a #2 Phillips head screwdriver, a small flat head screwdriver (to pry apart the switch), some steel wool or small grit sandpaper, some contact cleaner and some dielectric grease.
I remembered that there was a link on the Shop Talk page that was very explanatory about this procedure.  Looked it up and it is still there, but the pictures are not.  Unfortunately, I've found this to be the case more and more on the old Shop Talk page as we and our Valkyries age...
 Smiley
da prez
Wilmot Wi
« Reply #1 on: September 02, 2021, 12:27:27 PM »
I put a small cookie sheet lined with a soft cloth to catch the parts that may drop. The cloth prevents bouncing.  angel
          da prez
Bagger John - #3785
« Reply #2 on: September 02, 2021, 12:35:24 PM »
What are you using steel wool or sandpaper on in that switch?
NEVER use abrasives on plated contacts. A burnishing tool, card stock and contact cleaner should be the only things drawn across them...unless you want to replace the switch very soon.
RonW
Newport Beach
« Reply #3 on: September 02, 2021, 02:57:39 PM »
I always suggest people inspect the spot welds on the start button. Is the weld on the headlight wire okay. The strands are grouped wider than the rest of the welds like some strands are partially severed. Perhaps just an optical. Nice pics.
2000 Valkyrie Tourer
« Reply #4 on: September 02, 2021, 07:09:11 PM »
One of the most important things to check/fix is that the little brass double contact can bounce up and down in its slot. Due to heat the plastic can deform and bind the contact so it can’t bounce back up so WHEN it gets pushed down it’s stuck and you lose contact. A small exacto type blade can easily clean up that slot so the contact is free to move.
RonW
Newport Beach
« Reply #5 on: September 02, 2021, 08:07:00 PM »
agreed, if the slots for the legs are encrusted, the spring won't be able to push the bridge up against the electrical contacts.
f-Stop
Driftwood, Texas
« Reply #6 on: September 03, 2021, 05:06:01 PM »
Glad you mentioned this...that little contact was kinda stuck in the slots, so I used a small X-Acto like blade to carefully reshape those slots.  Figured I had one chance to get it right, so I took my time.
I agree, but I believe those contacts to be solid copper.  If not, you'd see some other metal showing through in picture #8.  Now given that, making the contact a bit more abrasive could shorten the life of the contacts, but more likely it will seat in nicely and work fine for another 24 years.
Good point! Those welds seem to be encased in some sort of plastic cement which holds the wires and the contacts in place.  Those exposed strands are held solid in place.  They don't move at all.
dago mooserider
San Diego, CA
« Reply #7 on: September 04, 2021, 08:24:45 AM »
It’s good u posted about this. I had the same problem crop up when trying to leave a buddy’s house last year. We got a test light and were scratching our heads for quite a while. Jiggle the starter button and poof light came on.  I didn’t fix right away and noticed that it was happening when very cold out.
-Matt
« Reply #8 on: September 04, 2021, 09:07:07 AM »
You need to check out Chet's Circuits for the Start Switch Safeguard mod. It inserts a relay in the headlight circuit that takes the large amp load off the start switch, when you press the start switch it only activates the relay using a fraction of the amperage(well under 1 amp). Result...no more burned contacts because there's no more arcing, among other things.
Scroll about 2/3 the way down for instructions.
https://web.archive.org/web/20110511130823/http://www.rattlebars.com/valkfaq/circuits.html
« Last Edit: September 04, 2021, 09:10:40 AM by John Schmidt » Logged
h13man
Indiana NW Central Flatlands
« Reply #9 on: September 05, 2021, 06:13:13 AM »
Mine quit @15yrs./14,000 mi. I bought a new assembly and replaced it and kept the old one with the rest of my stock parts. The part # was changed from the original when I purchased the new one thus showing two different.  https://www.servicehonda.com/oemparts/a/hon/506cb618f870023420a41739/switch-cable
SWITCH SET, STARTER STOP
35013-MZ0-000 35013-MZ0-020
$83.94
pancho
Bonanza Arkansas
« Reply #10 on: September 05, 2021, 06:48:18 AM »
Just for the sake of technical clarity on the "tech board", those connections are not spot welds, or welds of any kind, they are soldered connections. The processes are completely different and used for different purposes on different types of materials.
I agree, very nice pictures,, good camera.
Just for clarity......    Yeah, me and Monk are a lot alike!
« Last Edit: September 05, 2021, 06:49:59 AM by pancho » Logged
RonW
Newport Beach
« Reply #11 on: September 05, 2021, 10:06:50 AM »
i understand. it's okay.
pancho
Bonanza Arkansas
« Reply #12 on: September 05, 2021, 04:28:53 PM »
Thanks Ron uglystupid2
