March 23, 2026, 12:33:54 PM *
Author Topic: Airbox  (Read 824 times)
idaida98
« on: September 03, 2021, 06:30:18 AM »
Ok one question,does anyone have a fix for getting the air box back in?  tickedoff
« Reply #1 on: September 03, 2021, 06:44:29 AM »
I used a ratchet strap.
MAD6Gun
New Haven IN
« Reply #2 on: September 03, 2021, 06:44:52 AM »
 Tie each pair of tubes together. Front two,middle two and rear two. Drop it through the frame rails. Reach in and cut the string. Tubes will pop outward. Push them down onto the carbs and tighten the clamps. Make sure to check the rear of the tubes with a small mirror. You don't want to fold over the tubes. Will cause a vacuum leak. Hope this helps...
« Reply #3 on: September 03, 2021, 06:55:52 AM »
Patience grasshopper  Cheesy
« Reply #4 on: September 03, 2021, 07:13:48 AM »
Yep, thats all I've used, patience. It came out, it'll go back in. As with most things mechanical, they come apart easier than they go back together.
« Reply #5 on: September 03, 2021, 08:29:31 AM »
       Ever attempt to put the pup tent back in the container it arrived in?  2funny Old trick I used Frequently working on Navy aircraft. Gits too frustrating walk away have a cup of coffee and a smoke. I do NOT smoke anymore but ya git the drift. Some times just gittin yer head right helps. Has ya changed an altenator yet?  Roll Eyes RIDE SAFE.
RP#62
Gilbert, AZ
« Reply #6 on: September 03, 2021, 08:31:19 AM »
Others have described it as trying to put an octopus in a straight jacket.
-RP
« Reply #7 on: September 03, 2021, 02:50:43 PM »
Or a cat in a bathtub full of water.  Wink
Which reminds me...years ago my daughter #2, jr. high age, had a run-in with my sister's Siamese. It hissed at her from a shelf in the laundry room and wouldn't let her get the vacuum cleaner. She tried to pick up the metal tubes for it and the cat struck at her, giving her a couple scratches. She banged the cat a couple times with the tubes then grabbed it by the neck and threw it in the dryer, slamed the door shut and put it on fluff with no heat for a couple minutes. Cat never bothered her again! Became a family joke later after she was married, her older sister told her new hubby the cat story and suggested he remember it. He said he wouldn't fit in the dryer, the sister simply said "don't bet on it when Tari's pissed."  Grin
Avanti
Stoughton, Wisconsin
« Reply #8 on: September 03, 2021, 05:30:18 PM »
Do it with the lid off.
idaida98
« Reply #9 on: September 04, 2021, 07:50:40 AM »
Glad that's done.Tied off the tubes,did need a third hand at times and lots of pushing and pulling,not a joy to do.Yes I have done the alternator and ujoint compared to the airbox they were not bad. cooldude
