February 12, 2026, 07:32:32 PM *
Author Topic: Final drive part#s  (Read 1435 times)
larue
Clermont,FL
« on: September 05, 2021, 08:34:36 AM »
 Hi guys , the final drive in one of my bike is down what looks like 30%, can  anyone here provide OEM parts numbers for the ring ,pinion gears and drive flange. Thank you all in advance
rws
1997 Valkyrie Tourer
North Dakota
« Reply #1 on: September 05, 2021, 09:42:45 AM »
Go here or to any other Honda online parts vendor and look up part numbers and availability
https://www.ronayers.com/oemparts/c/honda_motorcycle/parts
Original VRCC Member Number 697
1997 Honda Valkyrie Tourer - 2019 Honda CRF450L - 2021 Honda Rebel 1100 DCT
« Reply #2 on: September 05, 2021, 10:15:56 AM »
Hey larue, if you can find a 1500 GoldWing rear drive in good shape it might be a lot easier and cheaper to do. The problem (for me) with new gears is that you would have to use different spacers to get the lash  correct. If you press out a Goldwing hub you don’t need to go thru that procedure. (Along with it being much cheaper)
larue
Clermont,FL
« Reply #3 on: September 05, 2021, 11:35:42 AM »
Hi rob I agree but I just can’t tell from these online picture how good the parts are. That’s been my challenge
« Reply #4 on: September 05, 2021, 12:16:24 PM »
Maybe there are some shops in your area that do trike conversions. They could possibly have some you could get your hands on and see.
larue
Clermont,FL
« Reply #5 on: September 06, 2021, 05:26:07 PM »
I got lucky and scored one locally with only 16k miles
« Reply #6 on: September 06, 2021, 05:28:07 PM »
excellent  cooldude
pancho
Bonanza Arkansas
« Reply #7 on: September 06, 2021, 06:18:10 PM »
That is a lot better than having to build one.  Good call meathead.
« Reply #8 on: September 06, 2021, 11:12:21 PM »
I wish I had the confidence to adjust the shims in the drive gear and the pinion to get the correct lash. I’ve never done it yet in car or bike. Using that bluing stuff on the gears to properly judge the lash seems more like an art, than strict mechanics.
pancho
Bonanza Arkansas
« Reply #9 on: September 07, 2021, 09:50:31 AM »
I got a good idea from Ricky-D on that meathead. He used grease  to do his shimming and get the gear lash correct, I haven't tried it yet, but hope to get the chance one of these days.
The Valkyrie finals I've done, both with GW spiines and new parts, I have just used the splines and gotten the correct gear lash using the Valkyrie original ring gear spacer and ring gear.
« Last Edit: September 07, 2021, 01:15:08 PM by pancho » Logged
pancho
Bonanza Arkansas
« Reply #10 on: September 07, 2021, 06:28:42 PM »
Just looked at what I wrote in that last post, and it isn't very clear.  When I said, He used grease  to do his shimming and get the gear lash correct, I should have said, he used grease to check the contact patch between the pinion and ring gear instead of using the prussian blue for a tooth contact pattern check.  This seems to be an effective way to do the shimming of the pinion and height spacing of the ring gear. But this being said, I don't know that there has ever been a Valkyrie final drive that needed a pinion or ring gear, and it is a lot of work and time to set them up. I have only seen the splines worn out, and even spending upwards of $350 for a new gear set depending on where you buy your parts, you are still ahead by pressing off the new splines and junking the new ring gear and pinion. You still end up with a like new final drive with much less effort and labor to get the needed results. In my limited experience, the ring gear and pinion show no wear at all even after extended use when set up by the factory.
Still seems like it would be fun to set one up completely new, but I have never seemed to want to invest the  amount of time it would require. Also the time and expense to have a  set of pinion shims and ring gear spacers, plus the building or acquiring of the special tools to do the pinion.  Tongue
« Last Edit: September 07, 2021, 06:35:59 PM by pancho » Logged
