February 12, 2026, 07:32:35 PM *
Author Topic: Rear Wheel Dampeners  (Read 1253 times)
Shakie NC
Beulaville NC.
« on: September 09, 2021, 03:23:11 PM »
Hello all you Valkyrie riders, looking to replace my rear wheel dampeners at next tire change, replaced once with the neoprene ones that was being sold by someone on here if my memory serves . are they still available and if so where can I get a set, or do we have to try and fined the stock ones? thanks for any advice.
Shakie NC
« Reply #1 on: September 09, 2021, 03:51:51 PM »
I believe you are referring to Urethane dampers that were available from Shock bushing Gary who has passed away.  To my knowledge, OEM is your only choice.
« Reply #2 on: September 09, 2021, 07:43:08 PM »
OEM and buy the ones for the Interstate. They fit all the bikes and come as one piece instead of the rubber and metal insert as 2 pieces.
I've just spent 10 minutes trying to find the right part number for you. No luck. Maybe someone else will have it?
« Last Edit: September 09, 2021, 07:47:29 PM by Britman » Logged
« Reply #3 on: September 09, 2021, 07:51:34 PM »
Part numbers change don’t worry about part numbers. Order off the fishe at HDL, pro caliber or similar
« Reply #4 on: September 09, 2021, 09:20:56 PM »
Number one (1).    06410-MBH-000
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/GL1500CFA_(01)_VALKYRIE_INTERSTATE%2c_USA%2c_VIN%23_1HFSC410-1A200001/REAR_WHEEL/a4b814af-1ab0-4a3b-bd55-e33261c53cbd/3d5479d0-fa43-4f01-b994-c4e561fd9e5f/y
I seem to remember hearing that Honda discontinued the earlier (than interstate) 2-part dampers with separate rubbers and inserts in favor of the better Interstate design dampers.  In any event, you want the one piece set.
https://www.ebay.com/p/1030307784
« Last Edit: September 09, 2021, 09:26:57 PM by Jess from VA » Logged
