February 12, 2026, 07:32:12 PM *
Author Topic: Headlight not on, high beam still works. Fuse? Or something else??  (Read 1401 times)
Boxcar01
« on: September 09, 2021, 08:22:56 PM »
2000 Valkyrie. Just got it home, everything works great except today the low beam does not come on when I start the bike. High beam still works. I just got the bike I’m not very familiar with it yet. Does that sound like a fuse needs replaced? Any help appreciated, thank you
RonW
Newport Beach
« Reply #1 on: September 09, 2021, 08:32:00 PM »
sounds like the low filament is toast
2000 Valkyrie Tourer
Icelander
Snohomish, WA
« Reply #2 on: September 09, 2021, 08:33:06 PM »
After checking that the light is not burned out, follow this thread to see if you're having the same problem: http://www.valkyrieforum.com/bbs/index.php/topic,118728.0.html
1998 Valkyrie Tourer.
VRCC Member #36337
RonW
Newport Beach
« Reply #3 on: September 09, 2021, 08:58:57 PM »
in the former post, the problem wasn't a low beam off while the high beam was okay, both both beams wouldn't go on. The headlight wire is routed through the start button and reconditioning the start button fixed things.
« Reply #4 on: September 09, 2021, 09:14:56 PM »
And usually it's easy to see the one (low beam) filament burned, but sometimes it's not easy to see.
The only time I ever use hi beams is to flash people, briefly.  I've lost a pile of low beam filaments and never a high.
Bagger John - #3785
« Reply #5 on: September 10, 2021, 12:39:27 PM »
We must not ride the same roads.
When I'm out after dark in the far unlit unknown, my high beams get used a LOT.
« Reply #6 on: September 10, 2021, 01:05:03 PM »
I ride at night very little.
« Reply #7 on: September 10, 2021, 07:09:43 PM »
I run high beam all the time.  Except at night with oncoming traffic.  Mine is now an Eagle Lights Infinity Beam - LED.  But the power supply is the same even with my Hi-Power relay mod - of course not needed now but I installed it when it was still halogen with a 130/90 bulb.  Your problem is not a fuse - the same one powers Hi & Lo.  Look at the bulb first.  Then the dimmer switch. Lastly the lo beam wire from the dimmer switch.  Not likely the starter contacts as your Hi beam would also be out.
Boxcar01
« Reply #8 on: September 11, 2021, 03:09:54 PM »
Lucky me, just a bulb change  cooldude Grin
