February 12, 2026, 11:11:34 AM *
Author Topic: kill switch  (Read 2485 times)
longrider
Vernon, B.C. Canada
« on: September 10, 2021, 07:01:17 PM »
Can the kill switch be serviced?  I may have intermittent contacts in there
« Reply #1 on: September 10, 2021, 07:09:00 PM »
I know this is not the right answer but my kill switch got wonky once a few years ago. Bike wouldn’t start and after eliminating the usual suspects it came down to the kill switch. So, I sprayed a bunch of contact cleaner in and around the switch and functioned it a bunch of times and never had another problem in years and years.
WintrSol
Florissant, MO
« Reply #2 on: September 11, 2021, 09:19:30 AM »
Contact cleaner IS the first thing to try. After that, disassembly and buffing the contact areas with contact cleaner and something like a Q-tip; nothing abrasive, like steel wool or sandpaper.
Grey wolf oz
« Reply #3 on: December 03, 2021, 04:53:47 PM »
I believe i have seen notes on some ones notes on strip and rebuild of the kill switch possibly on UTUBE
I DO NOT touch my kill switch,  due to the intermittent issues, and if i ever get brave enough i will attempt replacement, however i have no idea what to use in place,
Any suggestions welcome
I kinda think a shadow may be compatible, though no idea where to start looking
JimF2424
Valkyrie
Gulfport MS
« Reply #4 on: December 05, 2021, 06:48:14 AM »
I had problems with my kill switch, put a screw in the red button so I wouldn't use it.  But finally bought the complete setup, the starter button broke.  Cry
Foozle
Lexington, KY, USA
« Reply #5 on: December 05, 2021, 07:45:42 AM »
IMHO, the kill switch is among the fiddliest gadgets to take apart and service (or, more accurately, to get reassembled back in working order!).  Not complicated - just difficult.
As others have stated, spray with contact cleaner and hope that works.  This is one area I would avoid "excess" disassembly unless absolutely necessary.
Terry
GWS
Central New York
« Reply #6 on: December 05, 2021, 08:06:25 AM »
If/when you service the kill switch, the first tool you'll need is a towel to cover the gas tank so a socket or screwdriver doesn't drop on the tank and make a little ding in the paint that will drive you crazy every time you see it!!
ridingron
Orlando
« Reply #7 on: December 06, 2021, 10:30:07 PM »
I haven't had problems with my Valk yet. On my other bike, I line up the WD 40 red straw on a switch seam and soak it. A paper towel or a shop rag to catch the over flow. I do both sides to include the kill switch, start button, high/low switch, horn button, etc. It usually last several years.
No worries about dropping tools or losing parts.
CoreyP
Bluffton, SC
« Reply #8 on: December 07, 2021, 07:17:27 PM »
Honda kill switches aren't hard to clean. You just have to remember there is a spring and a small bearing in there, don't lose them.
I still had a problem after cleaning the kill switch on my 1100 Shadow. End result was I bent the contacts up just a little bit to much sure they made good contact, that fixed the problem.
