February 12, 2026, 04:11:08 PM *
Author Topic: Turn Signals?  (Read 1650 times)
hueco
WACO,TEXAS
« on: September 17, 2021, 08:03:20 PM »
The right turn signal lights work as normal. But. I turn on the left turn signal the left front signal light goes completely out. The left rear turn signal starts blinging very fast. I can hear the relay clinking fast on the left and clinking normal on the right. The front left bulb is good. I checked ground. As far as I could tell ground is good. Any suggestions? Thanks. hueco.
« Reply #1 on: September 17, 2021, 08:09:36 PM »
Replace the front bulb.
WintrSol
Florissant, MO
« Reply #2 on: September 17, 2021, 08:36:50 PM »
I say that either the socket has a poor connection to the bulb, or the wiring between it and the switch is bad. BTW, it is normal for the running light to go out on the side selected.
RonW
Newport Beach
« Reply #3 on: September 17, 2021, 10:52:25 PM »
Hypothetically, if the left Front signal's high filament is out, the current going through the flasher will double since the current only has half the resistance to go through in the same circuit, in this instance, the left Rear signal's working high filament. Essentially, one bulb instead of two bulbs. The higher current will heat up the bi-metallic strip in the flasher faster. Making the bi-metallic strip click back and forth at a faster rate causing the good rear turn signal to blink faster. If you like, switch out the front turnsignal bulbs.
« Last Edit: September 17, 2021, 10:54:30 PM by RonW » Logged
2000 Valkyrie Tourer
WintrSol
Florissant, MO
« Reply #4 on: September 18, 2021, 08:33:21 AM »
That's exactly opposite of what happens; the resistance of the rear filament doesn't change, and two filaments in parallel are half the resistance of just the one. Half the current through the flasher will cause (in many flashers) rapid flashing, as a bulb-out indication.
If, however, the flasher type we use flashes slower to indicate a bulb out, then something is overloading his, possibly a partial short to ground in the wire to his front flasher.
hueco
WACO,TEXAS
« Reply #5 on: September 18, 2021, 11:16:10 AM »
Eureka. I discovered the culprit. A open circuit. It has Cobra spotlights. When I took them off to replace the seals and pulled them out of the way it disconnected the turn signal wire in the headlight housing. Doh. Plugged it back up. Viola. Fixed. Appreciate all the help.   cooldude
WintrSol
Florissant, MO
« Reply #6 on: September 18, 2021, 12:03:14 PM »
Thanks for telling us what you found; sometimes we never hear back. cooldude
RonW
Newport Beach
« Reply #7 on: September 18, 2021, 04:03:06 PM »
More people have destroyed their bikes than the plague. If bikes could talk.
