CoreyP
« on: September 20, 2021, 08:29:27 PM » |
I bought a desmog kit months ago thought being, if I don't need it, it should go. Those vacuum lines and valves can only cause problems. Finally desmoged the Valkyrie couple weeks ago.
Not hard to do. What was interesting was the condition of all the rubber hoses. Not good. The crankcase hose running back up to the air filter housing was shot, all oily and even with clamps was dripping oil all over everything. Fuel tank vent hose was all brittle. Etc.
My point to this is, if you have recently bought a Valkyrie you most likely want to take the tank and the air box off and check all the hoses in there. Every bit of rubber. Whether you desmog or not is up to you. The actual valves looked good and functional on my bike, it was all the hoses that were questionable.
Performance wise my bike now seems to be a little harder to start but I swear it's smoother from 2000-3000 RPM. I very well may have had a vacuum leak somewhere. Might be in my head????
Jims99
« Reply #1 on: September 21, 2021, 05:01:05 AM » |
With the heat these engines create, the rubber does eventually dry out. I have found only the vacuum lines and caps are a problem. The boots to the air box have always felt normal on all my valks. I used vacuum caps from the auto parts store once, didn’t last a year. Now I use red eyes products as they seem to last.
The light at the end of the tunnel, is a train. 99 tourer 00 interstate 97 standard 91 wing 78 trail 70
Bagger John - #3785
« Reply #2 on: September 21, 2021, 06:09:09 AM » |
I replaced the vacuum lines and caps with their Viton equivalents (Redeye, I believe) on both of my current Valkyries.
The other lines and hoses are checked regularly. So far, no issues at 20 and 22 years age, respectively.
If I lived in a hotter, drier climate I'd inspect and possibly replace much more frequently.
« Reply #3 on: September 23, 2021, 05:06:31 PM » |
The metal tubes to the bottom of the heads on my 99' IS where almost fully plugged with carbon.  Another item to check if you insist on keeping them on the bike. Can they be cleaned? Replace.
RonW
« Reply #4 on: September 23, 2021, 06:26:58 PM » |
ditto
« Last Edit: September 23, 2021, 06:28:40 PM by RonW »
2000 Valkyrie Tourer
CoreyP
« Reply #5 on: September 23, 2021, 08:32:31 PM » |
I had the same result with the bottom metal lines on my bike. Lots of carbon build up but I don't think that would actually effect anything?
Next thought was this. If those lines are getting carbon build up are the lines causing carbon build up inside the engine somewhere? On the valves?
RonW
« Reply #6 on: September 24, 2021, 12:08:00 AM » |
don't those thingies inject air into the middle exhaust?
Bagger John - #3785
« Reply #7 on: September 24, 2021, 06:49:40 AM » |
ditto  If you have an ultrasonic cleaner that's large enough, it'll clean those right out.
RonW
« Reply #8 on: September 24, 2021, 08:12:51 AM » |
they're off the bike. I did desmog.
« Reply #9 on: September 27, 2021, 04:50:50 AM » |
I did a hi-speed desmog and left those lines in place, cut them off and folded them over. Instead of replacing with plugs. On Deerslayer and Jade. George was desmogged with a kit. No difference in functionality, just in appearance.
oldbiker49
« Reply #10 on: February 11, 2022, 06:32:37 PM » |
where do you get vacum for pet rooster when desmog kit
« Reply #11 on: February 11, 2022, 06:37:44 PM » |
Can you run that one through again with autocomplete turned off? -Mike
« Reply #12 on: February 12, 2022, 09:44:50 AM » |
Your "pet rooster", i.e., petcock, has nothing to do with the smog equipment. It doesn't get its vacuum from there, it's taken off either #6 on the left or #5 on the right...totally separate from any smog junk.
da prez
« Reply #13 on: February 12, 2022, 02:11:34 PM » |
May want to check the intake runner O-rings. They have been known to fail. The intake to runner boots and clamps may need some tlc.
da prez
