December 28, 2025, 08:25:43 PM *
Author Topic: 1500 Standard rear shocks  (Read 3344 times)
superjoe37
« on: September 23, 2021, 07:34:16 AM »
Fellas, I am looking at potentially replacing my rear shocks. I have seen posts on I/S shocks but not sure if the same info applies to the standard? Also, i am about 5'10" 190lbs and my only (somewhat) complaint about my bike is I am not as low to the ground (flat footed) as I'd like to be. If I understand it correctly the stock shocks are 13" and the progressive 412 series offers 11.5, 12, 12.5, and 13. Would there be any problems going with the 12" shocks and would that actually get me lower to the ground? Thanks!
« Reply #1 on: September 23, 2021, 07:44:11 AM »
No problem, ran 12" on my Tourer for years. Many others run 11.5".
CoreyP
Bluffton, SC
« Reply #2 on: September 23, 2021, 08:43:41 PM »
I would suggest Bitubos. That's what I have on my bike now. I'm 6 ft and have no trouble with the stock height, I don't think an inch off would be a problem.
I got my shocks from here, https://traxxion.com/, tell them what bike you have and they will get the right shocks and set them up for you. They'll ask what weight you are and how you are riding.
mello dude
Dayton Ohio
« Reply #3 on: September 27, 2021, 11:37:25 PM »
Having screwed around with the stock shocks, I  had never tried setting on number 1 until today...........I  just assumed it would  bottom out and be harsh.  Well, I was wrong....Day..Umm...... Jeez.  The number 1 setting on the rear shocks work out smooooth.....whoa I like...I'm really surprised...... cooldude
OK....check replacement aftermarket shocks off the list . cooldude
For info ....I  weigh 170 lbs.....
« Last Edit: September 27, 2021, 11:47:56 PM by mello dude » Logged
Bagger John - #3785
« Reply #4 on: September 28, 2021, 06:15:09 AM »
How many miles on the bike?
Eventually they'll get to the point where the dampers wear out and you'll have to consider a refit.
« Reply #5 on: September 28, 2021, 07:19:28 AM »
very dangerous, bike will wallow badly under certain bump road conditions at speed, can become uncontrollable and result in going down.  experienced it when I first installed I/S shocks on my tourer, they where set on two. I run them on three and everything is perfect.
what yr is your bike? '97-98 shocks have very harsh compression and rebound settings.  '99 and on have much better smoother settings, same as the I/S shock settings except for the heavier springs of the I/S.
« Reply #6 on: September 29, 2021, 08:05:56 AM »
Contrary to what some say, setting #1 is not inherently dangerous. I would ride over some bumps at speed and see how they react though.
you are incorrect.  if the suspension is overloaded just from speed, cornering forces, rough road, etc., due to the bike being undersprung, i.e. shock/s set without enough preload for the conditions mentioned bad things can happen very very fast.
just cruising streets going straight low speed, then is doesn't make a difference.
mello dude
Dayton Ohio
« Reply #7 on: September 29, 2021, 10:12:27 PM »
To the naysayers - its fine... for the bikes mission to cruise around SW Ohio backroads.... the bike will never leave the state.
The bike is a '99.. - I did replace the front springs...
« Last Edit: September 29, 2021, 10:24:05 PM by mello dude » Logged
Bagger John - #3785
« Reply #8 on: September 30, 2021, 05:53:22 AM »
Those are fairly flat (I've been there, done that) and hopefully still in good repair.
Come to northeast Ahia and this pavement will challenge even the highest-end aftermarket suspension setup.
« Reply #9 on: October 01, 2021, 09:31:12 AM »
if u are getting a harsh ride have u checked the upper shock bushings?
psckam
Elmira, New York
« Reply #10 on: October 28, 2021, 05:55:59 AM »
Just curious but if shocks were dangerous at the lowest setting why would they have that feature. I'm sure the lawyers would be  lining up for that cash cow.
« Reply #11 on: October 28, 2021, 06:50:41 AM »
if one pushes a motorcycle towards its limits at higher speeds and encounters rough bad roads while leaned over with under-sprung suspension bad things will happen fast due to the suspension fully compressing and hitting the internal stops and then hard parts hit the road.
one has to do baseline suspension adjustment for correct handling on a motorcycle with all added weight.
owners manual pg 17 states
"position 1 for light load and smooth road conditions.
position 2 is std position"
when entering a curve at speed the suspension can get overloaded.
https://vehiclephysics.com/advanced/how-suspensions-work/
https://www.superbike-coach.com/coachs-blog/coachs-motorcycle-support/motorcycle-suspension-guide
Knapdog
South Wales, UK
« Reply #12 on: July 15, 2022, 07:41:18 AM »
I'm looking to change my rear shocks also.
I've a 1998 Tourer with only 14,000 miles.
I've done 1000 miles in it now and would say I'm a bit disappointed with the ride. I have it on setting 3  have tried other settings but generally find the ride hard and not the sumptuous ride I was expecting.
The bike is going in to the local dealership for fork refurbishment, seals, bushes, oil etc but I'm keeping the springs.
Lots of you seem to go for Progressive 412 shocks but they're not easy to get in the UK. I believe the oem shocks are 13" so do I replace with the 13" Progressive? Quite often, on ebay for example, they're advertised as fitting a Harley Davidson. When I type in the Gl1500 Valkyrie it says they won't fit my bike. Can I ignore that?
I'm 180lbs and very rarely carry a pillion passenger, if that helps.
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
« Reply #13 on: July 15, 2022, 08:47:56 AM »
the '99 to '03  std and tourer shocks have better valving like the I/S shocks for a smoother ride. usually can be had on ebay for low cost.
  '97 and '98 shocks provide a terrible ride as u have noted.
« Reply #14 on: July 15, 2022, 10:25:50 AM »
The fellow I rode to InZane with got a set of Bitubos recently. He
really likes them. I might get a set...
Ron in Buffalo
Buffalo, NY
« Reply #15 on: July 16, 2022, 08:38:04 AM »
I bought Bitubos from Traxxon Dynamics and would recommend them.
1997 Valkyrie & 2002 BMW F650GS
Tazman11
Idaho
« Reply #16 on: July 16, 2022, 10:49:06 AM »
Ron, do you mind me asking what you paid approx. Thanks
Ron in Buffalo
Buffalo, NY
« Reply #17 on: July 17, 2022, 04:23:53 PM »
I think around 500.00 dollars. This was in 2020.
