February 12, 2026, 04:09:44 PM *
Author Topic: Tail light  (Read 2024 times)
radwhopper
« on: September 29, 2021, 03:04:46 PM »
I'm having trouble with the tail light not working. Brake lights work fine but no tail light. It has a LED bulb . I checked the fuses and they check good and I checked for current across the fuse and the fuse clamps. And checked at the tail light bulb socket. I think it's the bulb but I want to replace with a regular bulb and want to know if anyone knows the GE or Sylvania replacement bulb number for the Honda OEM? I can't make the number out on the LED.
« Reply #1 on: September 29, 2021, 03:14:30 PM »
I can only tell you (unrelated to bulb types) that sometimes the tail light wiring in the rear fender gets a little loose, and then gets rubbed by the tire on bumps (shock compression).  It's hard to work in there with the tire on, but you can get a light and look up underneath.
Mine was very intermittent, so looking at the usual suspects of fuses and power was no help at all.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: September 29, 2021, 03:45:17 PM »
Taillight bulb is 1157.
RonW
Newport Beach
« Reply #3 on: September 29, 2021, 07:47:49 PM »
in the tail light, the low-filament puts in many more hours than the high-filament (brake light) so it gets used up quicker. Inspect the tail light bulb, and if both filaments are still intact, try replacing the tail light bulb temporarily with the front turnsignal's bulb (another 1157).
« Last Edit: September 30, 2021, 11:05:42 PM by RonW » Logged
2000 Valkyrie Tourer
« Reply #4 on: September 29, 2021, 07:56:51 PM »
LED, Ron.
« Reply #5 on: September 30, 2021, 08:41:30 AM »
Best taillight replacement. I’ve had two on my last two Valks. Brightest taillight available.
https://www.amazon.com/Radiantz-Tail-Light-Honda-Shadow-Valkyrie-VTX/dp/B000TK8LY8/ref=sr_1_3?dchild=1&keywords=Valkyrie+LED+taillight&qid=1633016381&sr=8-3
Bagger John - #3785
« Reply #6 on: September 30, 2021, 09:26:06 AM »
Have one of those on my I/S.
Will eventually replace the Tourer's taillight with one, as part of changing over all its lights to LEDs.
RonW
Newport Beach
« Reply #7 on: September 30, 2021, 11:07:58 PM »
LED, Ron.
whoops
jnicks01
Clinton, IN
« Reply #8 on: October 01, 2021, 05:41:10 AM »
1157 bulb number
I want to scoop out your brains and eat your knowledge.
