February 12, 2026, 05:58:21 PM *
Author Topic: Alternator removal 99 Standard  (Read 1990 times)
Whooray
Idaho State Rep
Kuna, Idaho
« on: October 16, 2021, 01:10:02 PM »
OK I've done it once a long time ago, but for the life of Me I can't get the Alternator out. It's unbolted and loose. Any help/advice is appreciated.   Raymond
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
« Reply #1 on: October 16, 2021, 01:16:14 PM »
I just did an alternator change today. So here is my best advise. First remove both side covers. Then remove both bolts that secure the center cover. Then make sure the battery is disconnected. Pop the center cover out of it’s grommet and that gives you all the room you need. Once the alternator is free of the engine, point the rear of the alternator down and towards the center. Rotate the alternator a bit clockwise and it should come out. Be sure to massage wires hoses and such away from where you need the alternator to go.
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #2 on: October 16, 2021, 01:20:51 PM »
You were absolutely right!  It came out first try. Thanks so much!
« Reply #3 on: October 16, 2021, 02:23:37 PM »
You’re welcome  Wink
« Reply #4 on: October 16, 2021, 03:51:28 PM »
When you put it back in have a flashlight handy. You use the flashlight to make sure the blades of the alternator drive are aligned with the openings of the rubber dampeners. There are four pairs of rubber cushions tied together so there are four gaps where the blades need to align with.
« Reply #5 on: October 17, 2021, 07:43:53 AM »
Also need to put the rubber dampers in the "X" position so gravity doesn't pull them out of position.
« Reply #6 on: October 17, 2021, 08:16:15 AM »
Never thought of that but in makes sense
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #7 on: October 17, 2021, 12:47:37 PM »
OK the rubber dampened in the 10 o'clock spot keeps slipping down anyway to keep it in position?
« Reply #8 on: October 17, 2021, 01:01:27 PM »
Not really but if you get a Qtip and paint the dampeners with rubbing alcohol in the slots where the blades go it will slide right in
« Last Edit: October 17, 2021, 01:31:14 PM by Chrisj CMA » Logged
« Reply #9 on: October 18, 2021, 04:30:31 AM »
A little dab of grease on them will keep them in place.
I installed new ones when I changed my alternator, they stuck in there
pretty well...
« Last Edit: October 18, 2021, 04:32:57 AM by hubcapsc » Logged
