February 12, 2026, 05:57:35 PM
Rear drive gear
Topic: Rear drive gear (Read 1163 times)
TrapperAH1G
Toledo, WA
Rear drive gear
October 16, 2021, 04:23:18 PM »
Guy is selling rear drive gear for 1990 GL1500, 38K miles. Looked it up and for my 2000 Standard there are 3 gear numbers listed. On the 1990, the gear number matches one of those for my Valk. Holder plates are the same part number on both.
Is there a difference in the 3 gears listed as OEM for my bike? Or maybe they were from different vendors?
Don't know that I need one right now, but thought I might put it on the shelf for later.
thanks
Re: Rear drive gear
October 16, 2021, 04:39:11 PM »
Not sure what you mean by rear drive gear. If you mean the final drive the rear drive hub the differential. They are all the same. All will interchange.
Re: Rear drive gear
October 16, 2021, 04:49:43 PM »
gears from a Goldwing GL1500 final drive any yr do fit into the final drive of any GL1500 Valkyries.
the splines in the ring gear after being pressed out and the spline cup interchange.
