February 12, 2026, 01:35:59 PM *
Author Topic: Car tire  (Read 1611 times)
spurliner
alberta.....near calgary
« on: October 16, 2021, 10:25:20 PM »
I’d like to know if anyone on here is running the Firestone transforce cv 195/75/16? I’m thinking about running it myself … but my concern is it might be too tall and rub the underside of the fender. Anyone having problems with that?… thanks.
Andy.
1999 Interstate--
« Reply #1 on: October 16, 2021, 10:41:49 PM »
Considered it a while back but...
I think that tire is even slightly taller than the discontinued Austone Taxi Tires.  Heads up, I did rub the fender a bit when riding two up with Austones, even with Progressive 444 heavy duty 13" shocks.
If you pull the trigger please let us know if they fit!
h13man
Indiana NW Central Flatlands
« Reply #2 on: October 17, 2021, 07:03:07 AM »
I believe a member here installed this earlier this year as it stuck with me being a truck tire.
« Reply #3 on: October 17, 2021, 07:19:03 AM »
I'm currently running light truck tires on both bikes.  Zeetex CT-1000.  Love 'em!
« Reply #4 on: October 17, 2021, 07:31:01 AM »
I am also running Prog 444 13" shocks & Austone tire.  I'm not a lightweight either.  I also tow trailers. A couple variables here that can affect rubbing besides the shock height.  1.  Overall weight on the back.  2.  Which model 444's (or whatever shock brand/model), what height - OEM is 13", shorter can cause rubbing -and what preload setting. I did testing on diff models and arrived at the 4057 which is 13",  has 140/200 springs and I leave them set at max preload.  The spring rating is printed on Progressive coils.  I don't get dragging but rarely ride 2 up, and the trailer tongue weight is less than a co-rider even with the heavy Timeout camper.
« Last Edit: October 19, 2021, 11:07:38 AM by MarkT » Logged
Earl43P
Farmington, PA
« Reply #5 on: October 17, 2021, 09:53:12 AM »
That tire is 1.2” >diameter than my 205/65-16. No bueno, probably hit the fender.
I ran a 195/55-16 once but it sat pretty low and affected the kickstand angle. Made it quick off the line.
Only lasted 14k miles, I posted that travail years ago when my splines failed.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
spurliner
« Reply #6 on: October 17, 2021, 02:49:27 PM »
What size are those tires?
1999 Interstate--
« Reply #7 on: October 17, 2021, 10:45:36 PM »
LT195/65R16.  8 ply beefy.
0leman
Klamath Falls, Or
« Reply #8 on: October 18, 2021, 07:53:40 AM »
Got pretty close to 7K miles on mine (Zeetex), like it so far.
spurliner
« Reply #9 on: October 18, 2021, 10:15:08 AM »
Nice… did you have to do the nut cage mod?
1999 Interstate--
TrapperAH1G
Toledo, WA
« Reply #10 on: October 18, 2021, 06:12:07 PM »
I run a 185/75 on mine and yes, it rubbed 2 up.  Did the nut cage mod and "reworked" the wiring a bit to make it work.  Installed 12.5 shocks, run them on 3 with my better half on board and so far no further issues.
BTW, love the CT.
0leman
Klamath Falls, Or
« Reply #11 on: October 19, 2021, 07:59:45 AM »
I had to do the "nut cage" on my first tire,  205/65/17.    this tire is narrower so one probably would not have to do the "nut cage".
spurliner
« Reply #12 on: October 19, 2021, 10:17:47 AM »
that's what I was thinking
1999 Interstate--
Fazer
« Reply #13 on: October 21, 2021, 11:48:01 AM »
I would do the nut cage mod even with a standard MC tire.  Much easier to get hex nut started over the insidious square nut in the cage.
Nothing in moderation...
« Reply #14 on: October 21, 2021, 06:20:38 PM »
I didn't have to do the  crazy2 (nutcase) mod for this tire.
