December 14, 2025, 11:29:46 AM *
Author Topic: Larin bike lift and Ross Spoonland adapter fits Valkyries  (Read 2406 times)
Thunderbolt
Worthington Springs FL.
« on: October 21, 2021, 04:33:43 PM »
I have used this many times when we had our Valkryies. You bolt the steel lift adapter to the bottom of the engine case with two 90 degree bolts then slide the Larin lift underneath.  It is drilled and tapped for bolts to anchor the bike to the lift and two for stops.  You can raise it off the floor and remove either wheel and the bike will stay nice and stable.  Pickup only near Worthington Springs Fl.  $100 or fair offer.  I have a ton of old NGK plug pulls if you want them and I also have a few more miscellaneous pieces that I have run across after selling most of the other pieces and parts a couple of years ago.
Don't ask me how I know but you can actually ride the bike with the adapter attached however it is not advised.
We also have a standard rear seat like new if anyone can use it make an offer to pick it up or add shipping to your offer.
sixlow
St. Augustine, Fl.
« Reply #1 on: October 22, 2021, 02:24:00 AM »
I think High stepper could use this Terry, will check with him shortly.. cooldude
Thunderbolt
« Reply #2 on: October 22, 2021, 03:51:25 AM »
O.K. sounds good, it just needs to be used instead of collecting dust.
High-Stepper (Thomas)
Jacksonville, FL
« Reply #3 on: October 22, 2021, 05:42:11 PM »
Yeah thanks sixlow. Thunderbolt would like to talk to you about this. sixlow gave me your number will give you a call in  the next few days. Thank you
Thunderbolt
« Reply #4 on: October 23, 2021, 03:43:59 AM »
Sounds good, yeah got a text from Mike.
