February 11, 2026, 09:58:48 PM *
Pages: 1 [2]   Go Down
Author Topic: Hydraulic lift jack UK  (Read 5727 times)
psckam
Elmira, New York
« Reply #40 on: November 02, 2021, 05:00:26 AM »
(If your front end flops it will damage a tank some padding up there to be safe.)
Curious..How does that happen?
When I turn my bars fully to either side nothing contacts the tank.
Valklee
Bedfordshire UK
« Reply #41 on: October 23, 2022, 05:37:52 AM »
Without a specific adapter you can't use a standard lift.
 I have some adapter plate plans  I can send you,
Hi Mike
Any chance you can send me the plans as i have the Switzer as well and very pleased with it, does
slowly go down if left over night ,but as long as the arm is locked in one of the notches it holds it well
-mike-
Germany
« Reply #42 on: October 23, 2022, 11:02:59 AM »
Hi Mike
http://www.herberts.org/wayne/valk/lowtechlift.htm
you may also ask MarkT for an adapter than can be mounted and will stay on your dragon:
http://www.valkyrieforum.com/bbs/index.php/topic,105040.0.html
Best of luck!
-mike-
« Last Edit: October 23, 2022, 11:05:10 AM by -mike- » Logged
Valklee
Bedfordshire UK
« Reply #43 on: October 23, 2022, 11:19:07 AM »
Thanks mike, I have seen them but I was under the impression that you had some plans for a metal version as you stated " if you are capable of cutting and welding steel " ?
-mike-
Germany
« Reply #44 on: October 23, 2022, 11:39:01 AM »
my bad, I've searched for the metal plan, but have discarded the layout after buying a professional built metal adapter plate:
https://www.valkyrieparts.de/epages/63631381.sf/en_GB/?ViewObjectPath=%2FShops%2F63631381%2FProducts%2F%2299.09%20KV1%22
A jused one on ebay atm: https://www.ebay.de/itm/144775086559
here a plan that's quite sophisticated:
https://drive.google.com/file/d/1mh4fAMKkaeaGz7SnLKtVMqHBBpEBs-8m/view?usp=sharing
another wooden one:
EDIT:
Found it:
https://drive.google.com/file/d/14ggPcDIrglJMjgY45uV3-PnwlA4EG4Pz/view?usp=sharing
best,
-mike-
« Last Edit: October 23, 2022, 11:45:36 AM by -mike- » Logged
Valklee
Bedfordshire UK
« Reply #45 on: October 23, 2022, 12:39:17 PM »
Many thanks Mike for your time and effort to find this for me  cooldude
I like the look of this Metal one, will need to spend a few hours in my son's workshop
making it, as he now has all my cutting and welding gear there, will post a picture of the completed item.
« Last Edit: October 23, 2022, 12:46:49 PM by Valklee » Logged
Pages: 1 [2]   Go Up
