February 12, 2026, 01:34:58 PM *
Author Topic: Opinions on this Valkyrie please.  (Read 2266 times)
Bret SD
San Diego, Ca.
« on: October 26, 2021, 03:10:59 PM »
Valkyrie listed on CL for 2850.00, claims it's a 96.
https://sandiego.craigslist.org/csd/mcy/d/san-diego-1996-honda-valkyrie/7393392224.html
Here is a video of the bike running, to me it sounds like it takes a long time to start, mine fires up within a second or two with no choke on.. Keep in mind this is San Diego so it's not cold. When running, the engine sounds funny to me, as well as the exhaust. Of course it's hard to judge the sound of Valkyrie exhaust from a laptop sound system.
https://www.youtube.com/watch?v=q-0IQne7jmQ
« Last Edit: October 26, 2021, 03:13:39 PM by bretshim » Logged
Bret
02 Standard -- Blue & White
82 Aspencade -- Red
spurliner
alberta.....near calgary
« Reply #1 on: October 26, 2021, 03:24:14 PM »
sounds like there is something very wrong with the engine....? never heard that noise before...
1999 Interstate--
Bret SD
San Diego, Ca.
« Reply #2 on: October 26, 2021, 03:32:43 PM »
May be clanking from the belt pulley/tensioner..?.. or something. Whatever it is it doesn't sound good, and revving is very laggy compared to mine. It doesn't sound like a rod knock, you can't hear it too well from the side, only around the front.
Bret
82 Aspencade -- Red
Pete
« Reply #3 on: October 26, 2021, 04:42:29 PM »
Like others I did not like the sound or slow startup. Also noticed the bags look like they were not taken care of.
Needs some on site to inspect and listen. Be careful.
« Reply #4 on: October 26, 2021, 05:33:02 PM »
Ya it sounds like it’s not at full power. Something wrong
Rio Wil
« Reply #5 on: October 26, 2021, 05:43:31 PM »
Sounds to me like a cold engine being started with no choke and idling about 500 rpm with pretty much open exhaust......maybe a exhaust gasket leak at the head........warm that puppy and see if it sounds better.
« Last Edit: October 26, 2021, 05:46:54 PM by Rio Wil » Logged
« Reply #6 on: October 26, 2021, 08:21:24 PM »
       Even with my chintzy external speakers as a Guess this one is NOT firing on all six. See if they'll take a 800 and work from there.  worse come to worse you'll have at least that in parts. Either loose plug wires or an entire coil died! And if it's been laid up awhile Maybe stale gasoline. Could end up being a decent project. RIDE SAFE.
« Reply #7 on: October 26, 2021, 09:37:44 PM »
Keep in mind, if the carbs on these boxer type motors are way out of sync they will knock and rattle like that...if not worse. I had that once some years ago on an old 4 cyl. Wing motor, the guy wanted to get rid of it cuz he figured it was about to come apart internally. I took it off his hands, got home and set it on a makeshift stand, placed a gallon jug with fuel on my workbench and hooked a garden hose to it for cooling...didn't seal very good but worked. Got it started and what a racket, sounded like a door knocker on the front door. Shut it off, hooked up my 4 gauge set I used on the old fours and started it again. My suspicions were right, carbs were so far off I was surprised it even ran. About 15 minutes later it was smooth and quiet.
I feel the thing is idling too slow which will make out of sync sound even worse. I see it said the carbs were clean so if they were gone through, it's possible they weren't set up right when done. I'm betting a good carb sync and idle set to around 800 will make a big difference. JMHO
Earl43P
Farmington, PA
« Reply #8 on: October 27, 2021, 04:01:16 AM »
Cold start, low idle, questionable synch, exhaust isn't my taste but it's not obnoxious.
I'd HAVE to test ride it, but wouldn't offer or pay >$2k.
I'd expect that battery is weak because it fires up after he releases the start button.
Front tire looks ok, maybe the rear is worn, use that to talk him down.
Worth looking at if you're "looking" for another. Ride yours there to display how poorly his revs.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
Bret SD
San Diego, Ca.
« Reply #9 on: October 27, 2021, 05:41:15 AM »
I noticed his YouTube channel is called 'elgaragemotorcycles' and he has several recent videos of motorcycles and even a car or two. My guess is this guy picked it up for next to nothing, got it running and threw it on Craigslist for a quick sale.
The bags do look pretty bad though I think they can easily be refurbished to look like new. It's possible this thing has sat outside under a cover, which isn't ideal.
Good points here, it will definitely take an in-person inspection to see what's going on. I'm not convinced the carbs were rebuilt either, maybe he got lucky with putting additives in the gas tank.
I think it's, in the end, going to depend on what the guy's goals are with this thing. Obviously he wants to get the most money he can out of it, anybody in their right mind would not pay his asking price. The bike is open to be picked apart by a buyer, anywhere from tires to condition.. Especially the way it runs and sounds, he's going to have a hard time selling that bike unless he finds a real sucker. If it looks like it has good bones I might offer him 1500.. tops.
I think him seeing and hearing my bike run will be a wake-up call, he'll know exactly what a healthy Valkyrie sounds like.
It looks like he has an oil temperature gauge on top of the oil dipstick as part of the dipstick itself, I haven't seen that before. IMO the bike has nothing special going for it, and the fact that it's around 25 years old isn't going to help him much either. The cost of shop work isn't cheap these days and I can use that as leverage, I won't to tell him I do my own wrenching.
I'll try and get a look at it in the next couple days. Thank you for all the input, you've brought up some good points that I had not thought of.  cooldude
« Last Edit: October 27, 2021, 05:43:28 AM by bretshim » Logged
Bret
82 Aspencade -- Red
« Reply #10 on: October 27, 2021, 08:49:07 AM »
When you go to check it out, take an inspection mirror along and look at the settings on the sync screws on each carb. If the sync is way out in left field, those screws won't be even close to the same setting from one carb to the next. It's not a perfect test, but will give some insight.
Bret SD
San Diego, Ca.
« Reply #11 on: October 27, 2021, 09:29:02 AM »
It does have the oil dipstick temp dial. (They are pretty common) It has the chrome fork covers. Those are pretty hard to come by these days. (And worth a few dollars) It has several other add ons. Transmission covers, swingarm covers, lower engine cover, rad cover, Honda line fork deflectors, spark plug covers, newer model seat, and a few other things. It sounds like the slow jets are slightly clogged.
After posting what I did about it being nothing special I went back and started looking in detail at what it has on it. The radiator cover and the trim below it are nice, possibly the chrome mud flaps along with the other items that you have mentioned. I have the chrome fork covers on my bike so I'll have to compare the condition.
I think this bike when looking good and running in top form would easily sell for at least twenty-five hundred bucks.. Could be a no-brainer.
It also looks like it may have an LED tail light with a clear lens.. Have to look at that again, couldn't tell if the headlight is LED or not.
Bret
82 Aspencade -- Red
Bret SD
San Diego, Ca.
« Reply #12 on: October 27, 2021, 09:30:45 AM »
Good idea, thanks for the tip John.
Bret
82 Aspencade -- Red
Glaserbeam
Southern California
« Reply #13 on: October 27, 2021, 10:41:50 AM »
Having bought an '02 five years ago that had been sitting for 7 years, and also idled roughly with slow throttle response, I'd say that bike simply needs carb rebuild (why no carb caps on it?) a simple check of the valve clearances and timing, and possibly a new exhaust (sounds like drilled baffles).  I feel it's worth $1,500 to $2,000 as is, assuming the coolant looks clean (no internal oil/coolant leaks).  It's nicely accessorized.
« Reply #14 on: October 27, 2021, 03:31:00 PM »
I'd sure like to know where they got that lower front VALKYRIE adornment that drops down and protects the oil filter...among other things. Anybody have a clue?
Glaserbeam
Southern California
« Reply #15 on: October 27, 2021, 04:02:49 PM »
John, I see them on eBay every once in a while ... snagged a lightly used one in July.
Bret SD
San Diego, Ca.
« Reply #16 on: October 27, 2021, 04:22:17 PM »
Your assessment is pretty sound I'd say, I like the lower end of your price range.. the bike has been listed for over 2 weeks now, so he could settle for less. The great thing is I'm not feeling like 'gotta have it'!! Which puts me in a much stronger negotiating position.
Don't know why no caps on the carbs, that seemed a little odd to me as well.
Bret
82 Aspencade -- Red
« Reply #17 on: October 27, 2021, 11:59:55 PM »
Ad now removed.
pancho
Bonanza Arkansas
« Reply #18 on: October 28, 2021, 05:53:11 AM »
Somebody snapped up a good deal on a bike!           snoozers are losers
Bret SD
San Diego, Ca.
« Reply #19 on: October 28, 2021, 08:15:23 AM »
I've been monitoring CL daily for 3 years now, doing that I know what bikes sell and how much they sell for, at least a ballbark area. This one sat for over 2 weeks, the seller likely took a best offer around 2k is my guess.
There was a beautiful 99 BMW r1200c for 1800 in bumblebee colors recently, sold same day.. for asking I'm sure.
I'v learned you have to move quickly on the good ones, people like me are out there watching and waiting. I need to clear space and sell some things before I jump on a new to me bike.
« Last Edit: October 28, 2021, 08:22:07 AM by bretshim » Logged
Bret
82 Aspencade -- Red
« Reply #20 on: October 29, 2021, 04:53:39 PM »
Sounded fuel starved to me. Like when hou turn the Petcock off and let it run til it dies.  They will sound like that when reving the brown ngine just before it dies. Like it is running on 3-4 cylinders.
« Reply #21 on: October 29, 2021, 05:57:40 PM »
Me, I'm willing to pay more for something in good shape.
What I never set out to buy is a big pain in the ass project.
I always seem to have enough of those around my house without paying for them.   tickedoff
The only reason my last two vehicles were new (one car 2003, one truck 2017), is I don't want to work on them anymore.  All of my previous vehicles (and all but one of my bikes) were used.
Bret SD
San Diego, Ca.
« Reply #22 on: October 30, 2021, 04:01:50 AM »
I'm in this mindset too now Jess, though I have a hard time resisting diamonds in the rough.. obviously haha
My goal going forward is purging all but basic necessities, extra cars, tools, trailer, clothes.. everything is getting pared down. Simplicity and minimalism are where it's at.
Bret
82 Aspencade -- Red
« Reply #23 on: October 30, 2021, 05:43:29 AM »
Pairing down all the extra crap around my house is one of those big PITA jobs I avoid.  Grin
Just the other day, I realized my yard work pants were really getting threadbare with holes.  Rather than go buy some more, I realized I have a dozen pair of nice khaki dockers from my corporate casual days, and some of them will even button around my spare tire.  So they are getting re-purposed.
And my old wobbly Lazy Boy chair became spare seating (and sleeping) in my big Promaster van.
I pared down the 2d wife 11 years ago.
But no tools are being pared down.
Bret SD
San Diego, Ca.
« Reply #24 on: October 31, 2021, 07:25:21 AM »
Haha, good move if necessary  cooldude
Bret
82 Aspencade -- Red
« Reply #25 on: October 31, 2021, 12:08:15 PM »
Of course it was necessary, I just don't go around firing wives willy nilly.  It gets expensive you know.
She always said what's mine is mine, and what's yours is mine.... and the judge agreed.  Grin
Bret SD
San Diego, Ca.
« Reply #26 on: October 31, 2021, 02:09:33 PM »
Yep, they get the gold mine and we get the shaft.. or so 'they' say .. 'they' would be black robed messengers of joy  Evil Grin
Bret
82 Aspencade -- Red
Knapdog
South Wales, UK
« Reply #27 on: November 01, 2021, 03:31:18 AM »
A pal of mine had a BMW R1200C. The chrome came in two parts. Half of it on the bike and the other half on the floor.  Shocked
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
Bret SD
San Diego, Ca.
« Reply #28 on: November 01, 2021, 08:20:39 AM »
I read about that and a couple other issues to watch for, namely final drive seal and rear seal between motor and trans.. Those are the main ones to look out for but there's a few more. Mostly the seal problems occur from the bike sitting too much.
There is another 98 listed for sale here with 11,000 on the clock, looks like the pipe chrome is falling off and I'd be wary of seal problems.
Bret
82 Aspencade -- Red
