January 30, 2026, 08:00:41 AM *
Author Topic: Anyone used this Electric Fuel Valve before?  (Read 2706 times)
Larry
Northeastern BC, Canada
« on: January 13, 2010, 08:49:56 PM »
http://cgi.ebay.com/3-8-Electric-Solenoid-Valve-12-Volt-Air-Gas-Fuel-B20N_W0QQitemZ300383055716QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f039af64
It looks like the opening is quite a bit larger than the Dan Marc and would not impede fuel flow one little bit. Opinions?
« Reply #1 on: January 13, 2010, 08:55:38 PM »
    One of the statements in the ad says, Not suitable for gravity feed applications, so not good for Valk Applications?
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: January 14, 2010, 04:38:16 AM »
Buy the Dan Marc.  It's proven.
Marty
Daniel Meyer
The State of confusion.
« Reply #3 on: January 14, 2010, 05:23:42 AM »
That is a pilot valve. The solaniod doesn't actually open the valve...it opens a small "pilot" port and uses the pressure from the liquid/air/whatever to actuate the actual valve.
It needs pressure on the "tank" side to work. It's really for higher pressure applications. Not really suitable for gravity feed.
CUAgain,
Daniel Meyer
Larry
« Reply #4 on: January 14, 2010, 11:50:19 AM »
If I would have read the fine print, I would have noticed that it was a pilot valve and not bothered anyone about this, but they also make a semi-direct valve in 3/8" that would be fine for a gravity fed application.
http://cgi.ebay.com/3-8-Electric-Solenoid-Valve-12-Volt-Air-Diesel-B21N_W0QQitemZ300380678500QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f0156964
As well as a slightly different direct type in 1/4".
http://cgi.ebay.com/1-4-Electric-Solenoid-Valve-12V-DC-Air-Gas-Diesel-B20N_W0QQitemZ290387460793QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item439c7102b9
My concern with the Dan Marc was that it "only" has a 1/8" orifice size. I know several have used this valve and have had no problems and that there has been some discussion about flow rates in past posts. My thought is the easier the gas flows the better. Maybe I'm just being paranoid and 1/8" would be fine. A person could always try it and see how it performs I guess. Thoughts?
Dan Marc makes a 1/4" version but it also "looks" like a pilot valve.
http://www.dan-marcrvparts.com/12vo1ormupus1.html
Still working on my "get rid of the petcock" scheme and hooking direct to the tank with a low profile adapter and QD.
Daniel Meyer
« Reply #5 on: January 14, 2010, 12:03:18 PM »
That one looks suitable.
"Direct to tank"...got any plans to handle a reserve or just going to do without (just curious?)
CUAgain,
Daniel Meyer
Larry
« Reply #6 on: January 14, 2010, 04:49:24 PM »
Ya, going to go without a reserve.  Sad  Wings don't have reserves, my car and truck don't have reserves so I suppose I can get used to being with out on the Valk.  cooldude
Warlock
Magnolia, Ms
« Reply #7 on: January 14, 2010, 05:12:59 PM »
I have the Dan Marc on both of my Valkyries. I have just finished redoing my steering head bearings and wanted to see if I had any shake at 105 mph. I ran it up to 125 and still climbing, but I let off. So fuel delivery problem with the Dan Marc is no issue. And the solo one I play with running it hard on the low end with no bobble.
David
Larry
« Reply #8 on: January 14, 2010, 05:25:41 PM »
Is it the regular flow through unit with the 1/8" orifice?
Warlock
Magnolia, Ms
« Reply #9 on: January 14, 2010, 06:15:26 PM »
Yep. I was a little worried that it wouldn't deliver enough, but it has not problem.
David
Larry
« Reply #10 on: January 15, 2010, 11:34:18 PM »
Thanks for the input guys, appreciate it!  cooldude
