February 12, 2026, 01:34:48 PM
Adding a IS trunk to a standard question.
Topic: Adding a IS trunk to a standard question. (Read 1591 times)
Timbo1
Tulsa, Ok.
November 02, 2021, 01:05:20 PM »
As the title suggests I'm adding a IS trunk to a standard. The question I have is will the additional lights add to much load for the existing running / brake lights circuits if I just tie into the existing circuits? Should I add relay's or other options? My intention is to leave both fender and trunk lights operational as brake / running lights and blinkers only on fender license mount.
Bagger John - #3785
Re: Adding a IS trunk to a standard question.
November 02, 2021, 01:10:00 PM »
I've run them either way.
Best approach is to convert everything to LEDs and install an LED compatible signal flasher. I did this with my current Tourer and previous I/S, both of which have/had a full complement of lights.
November 02, 2021, 01:28:58 PM »
Even with just bulbs, the Valk charging system can handle that easily.
The trunk lights are all some weird small stab bulbs anyway, not even 1156/1157s.
LED turn signals have caused me so much grief, I would never do it again. (multiple bikes)
Timbo1
Tulsa, Ok.
November 02, 2021, 02:05:37 PM »
Thanks guys,
I'll just tie in to existing circuits. I like the kiss approach so tying in should get the job done pretty easy.
Gondul
VRCC #408
Central Florida
November 03, 2021, 10:14:30 AM »
I recently added the truck to my standard and went ahead and re-did all the wiring so I could make the trunk lights stop/brake/signals and installed LEDs everywhere.
I used LED 5 pin (waterproof) IPN connectors so I could unplug the whole thing and take it off if needed, added a PC8 Beaver and cleaned up the rat nest old me (who didn't know better 20yrs ago) left behind.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
