February 12, 2026, 05:01:41 AM
Drive Splines
Pages:
Topic: Drive Splines (Read 6633 times)
Re: Drive Splines
Reply #40 on:
May 17, 2022, 09:13:08 PM »
https://www.ebay.com/itm/273723676346?hash=item3fbb33d6ba:g:PM0AAOSw2fVdQJQK
OttawaWill
Ottawa, Ontario, Canada
Re: Drive Splines
Reply #41 on:
May 18, 2022, 05:41:25 AM »
"Hello,
Actually it does not work this way. It has Bookmarks on the left menu, where you can select a topic and navigate through it..
It is not a text searchable PDF. It has only scanned images"
That's a no go..
Re: Drive Splines
Reply #42 on:
May 19, 2022, 05:39:39 PM »
I did up a Notes: document, listed the page # and the Section/page and what the topic is.
If you want mine, just send me an email, I'll forward it to you. You just follow the format and add in the page # for the item you are looking for. You go to the end index, find the section/page, go to the page # to find it.
example:
Clyinder Head sec 8 pg 141
valve cover install pg 161
Clutch sec 9 pg 171
OttawaWill
Re: Drive Splines
Reply #43 on:
May 20, 2022, 04:23:23 AM »
Thanks for the offer... I found an option that allows to start words...
Last Edit: May 20, 2022, 02:01:10 PM by OttawaWill
Pages:
