February 12, 2026, 09:12:24 AM *
Author Topic: All Slow jets not fully screwed in.  (Read 1715 times)
Knapdog
South Wales, UK
« on: November 14, 2021, 03:45:19 AM »
I have a receipt showing work done on my Valkyrie in 2017,  in the States, a year before it came to the UK.
Including in the work was a carb strip down and sync.
As I've taken the tank off to attend to some rust I also took the carbs out for a quick inspection.
They were very clean though I noticed that all six Slow jets weren't fully screwed in. I think five of them were around a q/4 of a turn out and the other was closer to a 1/2.
Since I've had the bike it appears to be running fine though I've never come across another Valk to compare it with.
I've now fully tightened the Slow jets.
Has anyone come across this before and will it be OK to refit the carb cradle?
I presume that the Slow jets are meant to be fully in and I'm intrigued as to why they weren't
« Last Edit: November 14, 2021, 09:29:16 AM by Knapdog » Logged
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
Ron in Buffalo
Buffalo, NY
« Reply #1 on: November 14, 2021, 06:23:20 AM »
If it is running good why not reinstall it.
1997 Valkyrie & 2002 BMW F650GS
pancho
Bonanza Arkansas
« Reply #2 on: November 14, 2021, 10:14:32 AM »
I wouldn't think twice about it,,,  whoever put them in last, probably just had a lighter hand than you do. I don't think it will make any difference.
While they are opened up, if you are not going to separate them, I would at least pull all the removable parts for inspection and put the hard pieces in an ultrasonic cleaner.
« Last Edit: November 14, 2021, 10:25:00 AM by pancho » Logged
Knapdog
South Wales, UK
« Reply #3 on: November 14, 2021, 10:19:15 AM »
OK. That's what I was unsure of. So the fact that they weren't fully seated doesn't really matter.
Considering they were professionally done I still find it a bit odd. They're fully in now anyway. Thank you.
'96 Honda C90
'83 Honda C90C
pancho
Bonanza Arkansas
« Reply #4 on: November 14, 2021, 10:28:46 AM »
I don't think "professionally done" means anything more than they charged for their work.  Smiley
Jims99
Ormond Beach Fl.
« Reply #5 on: November 15, 2021, 04:41:13 AM »
That’s why most of us do our own work, hard to trust anyone to do anything right anymore. Yes, they should have been fully seated, snug is all you need, check everything else and you should be good to go.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Knapdog
South Wales, UK
« Reply #6 on: November 15, 2021, 05:05:03 AM »
Furthermore I've discovered the mixture screws were out a fair bit...
1. 6 turns out
2. 5 and 1/4
3. 4 and 3/4
4. 5 and 3/4
5. 4 and 1/4
6. 4 and 1/2
I presume setting them at 2 and 1/4 would be agreeable for all?
'96 Honda C90
'83 Honda C90C
h13man
Indiana NW Central Flatlands
« Reply #7 on: November 15, 2021, 06:28:52 AM »
That's where I'd keep them at.
Ron in Buffalo
Buffalo, NY
« Reply #8 on: November 15, 2021, 07:02:35 AM »
Me 2.
Bagger John - #3785
« Reply #9 on: November 15, 2021, 07:14:02 AM »
General rules of thumb when I'm doing carbs on these bikes (and I've done quite a few sets):
1) Pilots and mains are "snugged" with the appropriate JIS flat blade. My definition of "snug" isn't fully cranked down.
2) If the bowls haven't been off in a while, the bowl gaskets and the needle valves are replaced.
3) For #35 pilots, initial idle screw setting is 2 1/2 turns out. #38s are set at 2 turns.
4) Frequent plug reads are done to verify idle screw settings or to indicate they're necessary. I've actually had #38s run lean at those settings, and I've actually had #38s run so rich that #35s were swapped back in.
Lots of variables present. Tune according to your bike's equipment.
