March 23, 2026, 02:08:55 AM *
Author Topic: windshield question  (Read 895 times)
Jan
« on: November 20, 2021, 03:05:05 PM »
What is that windshield called that's about the size of a flyscreen but slopes back over the instrument pods?
« Reply #1 on: November 20, 2021, 08:50:24 PM »
Unavailable  coolsmiley
ridingron
Orlando
« Reply #2 on: November 20, 2021, 10:10:55 PM »
The generic term is "fly screen". If they're not available from Honda, someone will probably know of an alternate.
Ken aka Oil Burner
Mendon, MA
« Reply #3 on: November 21, 2021, 07:38:00 AM »
Are you talking about a cafe fairing maybe? They are low, and definitely slope back towards the instruments.
« Reply #4 on: November 21, 2021, 07:55:57 AM »
Like this?
http://www.nationalcycle.com/n2536.html
Or
http://www.nationalcycle.com/n2537.html
« Reply #5 on: November 21, 2021, 01:04:33 PM »
I do not get the purpose of fly screens.
They look like the same protection as putting a baseball cap on your headlight (bill forward).
You can kill a lot more flies with a real windshield.
This Memphis shades Big Shot is the smallest shield I ever ran (though I've been running fairings for 30 years).  They make progressively smaller ones that look about the same.
Big Shot.
Del Ray.
Pop Top.
« Last Edit: November 21, 2021, 01:10:57 PM by Jess from VA » Logged
h13man
Indiana NW Central Flatlands
« Reply #6 on: November 23, 2021, 07:33:53 AM »
On a note, I used handlebar mounted Slipstreamer 15" 06 Spitfire and the 17" larger overall Hellfire on the 1100 Spirit with great success. When I mounted the Hellfire on the Valk as 17" was the proper height on both bikes, the Hellfire couldn't withstand the sudden wind pressure that Valk can produce @ over 90 mph. speeds that occur when doing a quick pass on two lane roads. Had to reposition/tighten eventually 3x in 2 mos. Had to go to a fork mount shield. The Spitfire, 2x in 5 yrs. of service but the Spirit was bit of a dawg in comparison and it wasn't as massive either. I like shields but finding one that perfectly does its job w/o some buffeting, goodluck on your quest. Adding lowers on mine worked really well but in warmer months engine heat becomes a factor thus I use them very early spring and late fall or or not at all nowadays due less willing to ride in cooler temps.
« Reply #7 on: November 23, 2021, 01:40:09 PM »
I have to use a handlebar mounted windshield on my 1800 Valkyrie, which has 1500
Valkyrie bars on it, and I used two sets of Memphis Shades (?) mounting hardware...
h13man
« Reply #8 on: November 24, 2021, 06:53:37 AM »
And the shield you have mounted is a lot lower than the 17" Hellfire. A matter of the height/top of the shield to the clamp position/pivot point and not mention the angle placement of said shield/windscreen. Good on you that works for you. "To everything there exceptions."  cooldude
