February 12, 2026, 11:11:45 AM *
Author Topic: Front axle  (Read 1990 times)
Whooray
Idaho State Rep
Kuna, Idaho
« on: November 24, 2021, 10:13:39 AM »
What size is the Allen wrench side of the front axle?
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
« Reply #1 on: November 24, 2021, 11:04:34 AM »
17mm I think.
« Reply #2 on: November 24, 2021, 12:23:30 PM »
Yes it’s 17mm. However, I have never used that so I actually had to tap it in a few times to get it in there. It fits now cooldude
matt
Derry New Hampshire
« Reply #3 on: November 24, 2021, 04:41:01 PM »
Didn't I read somewhere that the sparkplug tool in tool kit fits in it?
« Reply #4 on: November 24, 2021, 04:49:02 PM »
Yes I believe you’re correct
RonW
Newport Beach
« Reply #5 on: November 24, 2021, 05:57:23 PM »
this is the thingie I use for the front axle. You won't actually need it if you tighten the left pinch bolts before you torque down the axle nut (per manual), but there's a "single wrench or two wrench" argument associated with tightening the right pinch bolts instead, and leaving the left pinch bolts loose until after you bounce the forks to set the front axle. The hex thingie does make it easier to adjust the position of the axle laterally in the forks.
You might read Cracker Jack post here on which fork to keep loose when you bounce the forks to set the front axle.
« Last Edit: November 24, 2021, 06:13:20 PM by RonW » Logged
2000 Valkyrie Tourer
mello dude
Dayton Ohio
« Reply #6 on: November 24, 2021, 08:32:11 PM »
The hex has a bit of a burr on it to make a key tight to use. I knocked off the burr on the end smoother with a file to get a small lead on it. --- For a tool, I bought this from Amazon, works great... (I see its unavailable for the moment.)
https://www.amazon.com/gp/product/B01MY5ATRL/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Here's one that says available now....
https://www.amazon.com/Titan-Tools-15617-Drive-Socket/dp/B004W81LPY/ref=sr_1_2?keywords=17mm%2Bhex%2Bkey%2Bsocket&qid=1637814996&s=hi&sr=1-2&th=1
« Last Edit: November 24, 2021, 08:39:36 PM by mello dude » Logged
