February 12, 2026, 11:11:51 AM *
Author Topic: Dust Guard  (Read 2378 times)
JimF2424
Valkyrie
Gulfport MS
« on: November 27, 2021, 09:02:54 AM »
I changed my rear tire, and greased the splines, not sure it the Dust Guard is setting properly.  Looks like it should be set back further, rode the bike a few miles, maybe 30 miles, and everything seems find.  But wondering is the dust guard set correctly.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: November 27, 2021, 09:24:12 AM »
Yep, it’s fine. Mine does that every time I service the final drive. After 200,000 miles, it still looks like that every time.
JimF2424
Valkyrie
Gulfport MS
« Reply #2 on: November 27, 2021, 09:33:28 AM »
Thanks for the feed back, just want to make sure.
RonW
Newport Beach
« Reply #3 on: November 27, 2021, 01:12:46 PM »
2000 Valkyrie Tourer
CoreyP
Bluffton, SC
« Reply #4 on: November 27, 2021, 08:47:41 PM »
Yes it looks disturbingly wrong but these guys say that's the way it should be.
I did the same thing, took the back wheel off and didn't really look at that. Put the wheel back on with my first thought being, that's not right.
The back wheel removal and service was an adventure.
Tazman11
Idaho
« Reply #5 on: November 27, 2021, 09:17:39 PM »
Same thing here. Didn’t look right. Reviewed the manual, searched the web, and said a prayer. Took the wheel off, inspected everything, reassembled and reinstalled, looked the same when I finished. I felt good about double checking everything.  Works great.
Knapdog
South Wales, UK
« Reply #6 on: November 28, 2021, 08:08:58 AM »
Very useful thread. I'm about to find out in the next couple of days.
Stay between the hedges!
'98 Honda Valkyrie Tourer⁸
'96 Honda C90
'83 Honda C90C
« Reply #7 on: November 28, 2021, 10:49:10 AM »
The first frustration for a first time wheel removal is if the flange decides it wants to stay with the final drive instead of separating with the wheel. If that happens put the axle back in without the spacer and brake plate, mate the wheel back up then get a screwdriver and under the drive there is a squarish hole. You can pry the flange out of the drive and make sure it is now mated to the wheel. Then remove the axle again and proceed.
RonW
Newport Beach
« Reply #8 on: November 28, 2021, 04:03:25 PM »
It's probably worth your while to stick a screwdriver in the 'rectangular slot' to start the rear wheel separation.
As long as you'e prying on the 5-star flange instead of the damper plate under the 5-star flange, the flange should remain on the wheel.
RonW
Newport Beach
« Reply #9 on: November 28, 2021, 04:10:41 PM »
Has anyone tried leaving the rear axle in while separating the wheel from the pumpkin? Naturally, it's better to wedge the rear wheel up to pull pull out the rear axle after the separation. Then the wedges under the tire have to be removed to roll out the tire, an extra step.
« Last Edit: November 28, 2021, 07:45:00 PM by RonW » Logged
JimF2424
Valkyrie
Gulfport MS
« Reply #10 on: November 29, 2021, 04:35:24 PM »
For anyone curious how I changed the rear tire.
« Reply #11 on: November 29, 2021, 05:37:07 PM »
Terrifying!  Shocked  Wink
RonW
Newport Beach
« Reply #12 on: November 29, 2021, 06:03:51 PM »
he got the handlebars strapped down to the wooden deck.
Trailer hitch is awesome!
RonW
Newport Beach
« Reply #13 on: November 29, 2021, 06:13:33 PM »
but how did he get the 2 x 4's under the swingarm. I think that's keeping the swingarm and pumpkin elevated
« Reply #14 on: November 30, 2021, 05:55:58 AM »
It looks like he has the lift adapter on the bike and is using that.
« Reply #15 on: November 30, 2021, 07:37:04 AM »
Wow, that flange looks like it’s been way to long since the last service. Hard to tell but looks like significant wear as well
Knapdog
South Wales, UK
« Reply #16 on: November 30, 2021, 07:55:59 AM »
Just wondering if the five shafts on the flange should be greased before reinserting. Shocked
'96 Honda C90
'83 Honda C90C
« Reply #17 on: November 30, 2021, 08:15:14 AM »
No
« Reply #18 on: November 30, 2021, 08:37:44 AM »
If you're leery of that dust cover you can post a pic here for opinions.  You definitely want it on snug tight, as water getting up under it is not a good thing.   Wink
JimF2424
Valkyrie
Gulfport MS
« Reply #19 on: November 30, 2021, 10:46:15 AM »
The 2x4 and 6x8 lumber is only for safety, the weight is actually on the jack stand.   I do have the left frame that I bought, attached, and the Belly Tank is resting on the lumber a little.
RonW
Newport Beach
« Reply #20 on: December 01, 2021, 03:21:50 PM »
..... that's not my bike. Just screenshot of somebody's video.
Knapdog
South Wales, UK
« Reply #21 on: December 04, 2021, 06:31:10 AM »
I took the wheel back off and refitted it twice and this is how it fits each time on my bike.
I don't think I'd be able to get it any snugger than this though I might have to try again if members think it's not right.
Despite any possible distortion on the pic the ridge on the wheel is the same all the way around such that the dust guard isn't at an angle.
'96 Honda C90
'83 Honda C90C
Valker
Wahoo!!!!
Texas Panhandle
« Reply #22 on: December 04, 2021, 11:42:28 AM »
Several folks who know what they’re talking about have told you already that it’s right. Still in doubt?
Knapdog
South Wales, UK
« Reply #23 on: December 04, 2021, 11:56:16 AM »
Fair enough.
'96 Honda C90
'83 Honda C90C
