December 13, 2025, 11:59:30 PM *
Author Topic: Front fender replacement ?  (Read 5536 times)
GMAK
« on: December 12, 2021, 02:20:20 PM »
Due to an unscheduled dismount, I will be needing a new front fender(among a few other items).
This unscheduled dismount was just caused by pulling away from a stop, and encountering/misidentifying a longitudinal territorial mismatch in road level (re)construction surface. Really, just a fluke, "wrong place", "wrong stop", "inattentive restart", "basically, an (eenie meanie), that should have been a (miney moe)".
A brief review of the the front fender graphic shows the unit a two pieces. I didn't know that! And, the only two sites visited for this
graphic review(Partszilla and Honda), list the #3 fender item as black. Is the front fender not available in the blue body color? Or, will there be a repaint need in my future.
Thanks....
Jack B
Two Rivers Wis
« Reply #1 on: December 12, 2021, 02:53:27 PM »
Honda usually has painted parts it would just be a different part number.
Let’s RIDE
baldo
Youbetcha
Cape Cod, MA
« Reply #2 on: December 12, 2021, 03:30:08 PM »
Check your model number on Partzilla. The black is a GL1800C2C. The '2' denotes black. There are several different flavors. Any painted parts should list the color.
« Reply #3 on: December 12, 2021, 04:51:16 PM »
I don't know why they list a color with those things but I
think they are rubber(?) pads inside the fenders.
GMAK
« Reply #4 on: December 13, 2021, 11:32:59 AM »
Thanks Jack B, Baldo, and Hubcapsc....
Yes, I was aware of the appended model designation when shopping parts.
I guess I didn't research the Honda/Partzilla sites as careful as I thought. Because a second review(as noted below), shows
the fender in two different configurations. My model type is "GL1800C3AC"(Blue).
1. Honda shows the fender in two pieces(#3, #5). And the "C3AC" designation doesn't seem to change the color from black
    to blue. This part, as listed, is $333.28.
2. Partzilla shows the fender in one piece(#5). And the "C3AC" designation DOES seem to specify the correct "BL" color. This
    part, as listed, is $332.03.
. I guess it works both ways:
  . The Honda unit(half unit), will ship black, to be used as is, or colored as needed.
  . The Partzilla unit(full unit), will ship blue, to be used as is, without further detail.
I can't recall ever seeing such a discrepancy in the same/similar part(Honda:61102-MCA-S40ZB ) vs. (Partzilla 61100-MJR-670ZB).
That's strange. But these plastic body parts are not painted, they are molded with the intended color. It would be very difficult for
someone like me to attempt a paint matching exercise. But, I guess the single piece fender is harder to install than is the two
piece unit.
Item(#3)
Honda: https://www.hondaparts-direct.com/oempartfinder?aribrand=HOM&arian=motorcycle#/Honda_Powersports/GL18003AC_(14)_GOLD_WING%2c_JPN%2c_VIN%23_JH2SC68W-EK000001_TO_JH2SC68W-EK099999/FRONT_FENDER/fd33d273-a94e-4eb1-b90b-745050c02190/dac74943-89da-4d8b-9e4a-8a53904d83dd/y
Item(#5)
Partzilla:https://www.partzilla.com/catalog/honda/motorcycle/2014/gl1800c-3ac-gold-wing/front-fender
Thanks again,
If I encounter subsequent importamt information, I'll update further.
GMAK
