February 12, 2026, 11:11:50 AM *
Author Topic: Final drive PDF file ?  (Read 1922 times)
bobber
« on: December 14, 2021, 10:23:10 AM »
Would someone be able to give me a link to a file that I think described servicing with a series of pictures?  Thanks
Louis
ohio
« Reply #1 on: December 14, 2021, 12:03:20 PM »
Excellent, Thank You !!!!!
« Reply #2 on: December 14, 2021, 12:16:17 PM »
The final drive URL  came from here.
http://www.valkyrieriders.com/shoptalk/
Go there and look around, there's a ton of
member supplied how-to stuff there.
There's a link to shoptalk on the board too...
RonW
Newport Beach
« Reply #3 on: December 14, 2021, 12:33:42 PM »
We were discussing the torque on the Stopper Bolt here. Scroll down to Post #11. Some members advise not to tighten it to 51 ft-lbs per manual to avoid a seized bolt later. Chrisj CMA who authored the PowerPoint Rear Wheel guide states that the Stopper Bolt simply serves as a pin.
« Last Edit: December 14, 2021, 02:47:39 PM by RonW » Logged
2000 Valkyrie Tourer
« Reply #4 on: December 14, 2021, 02:22:27 PM »
I work on several valks and have found that bolt very tight sometimes. I use a torque wrench to install it but use Never Sieze to avoid the rust or siezing in the future.
« Reply #5 on: December 14, 2021, 04:01:35 PM »
I have taken to using anti-sieze on all threads that I R&R.  And nearly always use a torque wrench.  No more worries on siezed bolts.
bobber
« Reply #6 on: December 14, 2021, 08:01:43 PM »
Thanks Hubcapsc, that's the one I wanted. And thanks to all the others for the information on drives!
