Stanley Steamer
« on: January 15, 2010, 05:28:27 PM » |
I had ordered some parts from HDL a couple of weeks ago and they just came in today....and I got my new bulbs for the pod lights from Big Mike yesterday..... The oil seal around my gear shifter had an oil drip on it and now I have a new one to replace it.....I also got some new rear brake pads.....a couple of parts for the rear brake caliper.....2 oil seal sets for the brake pistons, but I didn't order new pistons, now I'm thinking I should have??.... I also ordered a new spring for the kickstand and what I THOUGHT was a new bolt for the one that breaks?...but I think I screwed that up....I'm not sure I was looking at the right microfische for that bolt....Does anyone have that part # handy or maybe able to tell me what drop down screen it's found on??.. I also ordered a new petcock cover-set as a back-up in case that fails on me again(NO...no Pingel for me).... Now I just need a few days of warm weather and the time to replace the parts that need it....
Stanley "Steamer" "Ride Hard or Stay Home"
RoadKill
« Reply #1 on: January 15, 2010, 05:34:15 PM » |
It's 45 freakin degrees! How much warmer do ya need it? Grab a bottle of Wild Turkey Gold and GIT-ER-DUN !
highcountry
« Reply #2 on: January 15, 2010, 05:38:24 PM » |
+1
« Reply #3 on: January 15, 2010, 05:38:39 PM » |
Lots of good stuff Stanley... you probably don't need new pistons for your calipers... it might take a pretty studly air compressor to get them to pop out though... I got just such a compressor for Christmas  -Mike
Stanley Steamer
« Reply #4 on: January 15, 2010, 05:40:35 PM » |
It's 45 freakin degrees! How much warmer do ya need it? Grab a bottle of Wild Turkey Gold and GIT-ER-DUN !  I'm a Tee-totalor....I'd be liable to do something goofy if I drank alcohol......My little shed has no heat nor lights....I'm thinking that I'll wait until I have some 50 degree and above weather since I can't really heat my shop...
« Last Edit: January 15, 2010, 05:44:48 PM by Stanley Steamer »
Stanley Steamer
« Reply #5 on: January 15, 2010, 05:43:37 PM » |
Lots of good stuff Stanley... you probably don't need new pistons for your calipers... it might take a pretty studly air compressor to get them to pop out though... I got just such a compressor for Christmas  -Mike Can we use your new toy sometime then??....my little air compressor is only like 2hp with an 8 gallon tank...I mainly use it for finishing nailers in my woodworking shop....it handles that well!!..... I guess I'd like to change that gear shifter oil seal replaced first before I have a leak in front of a hardley.....
Stanley Steamer
« Reply #7 on: January 15, 2010, 06:27:32 PM » |
I ordered part # 6....BOLT, SPECIAL (6MM) 90111-MZ8-000 and part #...NUT, SIDE STAND 90203-MF9-710 I think I meant to order part #05 BOLT 90108-MR5-000 .....Is this the one the spring goes on??.....
« Reply #8 on: January 15, 2010, 06:45:44 PM » |
# 5 ? Is that the one that breaks ?
« Reply #9 on: January 15, 2010, 06:46:24 PM » |
I also miss order the same bolt. Had trouble reading it also. I just took mine off and put one from the hardware store in its place. Screwed it in lower so nothing will hit it. Then I got 2 other spares. Also got rid of the sidestand switch to. No Pingel yet?
Stanley Steamer
« Reply #10 on: January 15, 2010, 06:55:23 PM » |
# 5 ? Is that the one that breaks ? I'm not sure without looking at it on the bike...I guess I'll take a look at it this weekend just to make sure....
« Reply #11 on: January 15, 2010, 07:25:36 PM » |
# 5 ? Is that the one that breaks ? I'm not sure without looking at it on the bike...I guess I'll take a look at it this weekend just to make sure.... Let me know I'd like to get one to throw in the tool bag.
X Ring
VRCC #27389, VRCCDS #204
« Reply #12 on: January 15, 2010, 07:45:44 PM » |
What do you mean IF you drank alcohol. You don't need alcohol to act goofy. For you, acting goofy is a state of being.  Marty
Stanley Steamer
« Reply #13 on: January 15, 2010, 07:50:46 PM » |
What do you mean IF you drank alcohol. You don't need alcohol to act goofy. For you, acting goofy is a state of being.  Marty Well......I guess you may have me there.....it might make me MEAN though??......
RoadKill
« Reply #14 on: January 15, 2010, 08:08:31 PM » |
No heat or lights is why you need the drinky  Oh...wait,that's just me!  You are a smarter man than I......but that aint sayin much!
T-Bird
Cleveland, Tennessee
« Reply #15 on: January 15, 2010, 08:40:14 PM » |
Stanley/smokin'joe,
The bolt the spring attaches to is part # 50536-MZ0-010. It is located on the Frame section of the schematic. it is part #11 on the schematic
X Ring
« Reply #16 on: January 15, 2010, 09:13:03 PM » |
What do you mean IF you drank alcohol. You don't need alcohol to act goofy. For you, acting goofy is a state of being.  Marty Well......I guess you may have me there.....it might make me MEAN though??......  Mean like a cornered Winnie the Pooh?
Stanley Steamer
« Reply #17 on: January 16, 2010, 03:30:12 AM » |
Stanley/smokin'joe,
It looks like that is part #10(spring hook)...and that #29(washer)...part #11(breather tube clip) and part #17(nut) should all be ordered together in case the spring hook breaks as you're tooling down the road?.....I had looked at the frame schematic and figured it was on there...I'll go order those now....
« Last Edit: January 16, 2010, 03:38:20 AM by Stanley Steamer »
sheets
« Reply #18 on: January 16, 2010, 04:21:56 PM » |
I was going to attach a pic of the part and PN# but my firewall blocked the photo site. ???
sheets
« Reply #19 on: January 16, 2010, 04:32:53 PM » |
New one on me. PhotoStash has been blocked by my virus protection. I can't get passed it. Never had that happen before. ???
« Reply #20 on: January 16, 2010, 04:40:01 PM » |
get into photostash thru explorer use the firefox for everything else
T-Bird
« Reply #21 on: January 16, 2010, 08:34:23 PM » |
Stanley Steamer
« Reply #22 on: January 17, 2010, 02:06:44 AM » |
Thanks......I'll order one of those lickety split!!!....
