Bronxboy
« Reply #40 on: February 02, 2022, 02:36:56 PM » |
Pappy we can hook up around Perry or even closer, then head to Keith's. Will figure it out as it gets closer. I also registered, let me know when u guys book your rooms. We should all get a double queen room because a few people are still uncertain if they will make it.
« Last Edit: February 02, 2022, 03:10:42 PM by Bronxboy »
« Reply #41 on: February 02, 2022, 03:24:40 PM » |
Well, looks like I'll get to see some of the old Florida gang...and a few young ones also.  Keep your itinerary posted as you go along and maybe Dagwood(Tim Bumstead) and I can hook up along the way. That would be quite a group arriving if we made the last few hundred together.
Bronxboy
« Reply #42 on: February 02, 2022, 04:39:49 PM » |
Pappy!
« Reply #43 on: February 02, 2022, 06:01:14 PM » |
When I made room reservations there were only two double queen rooms left. I got one of them. I can switch with someone when we get there though and stay in a single king room so get booked up before all rooms are gone.
Farside
Let's get going!
S. GA - N. FL
« Reply #44 on: February 02, 2022, 06:44:58 PM » |
What days did you set up for at InZane. Arrive on Monday- check out on Thursday? That is what Nick and I discussed.
Farside
ridingron
« Reply #45 on: February 02, 2022, 07:25:29 PM » |
If you guys are going to sniff the flowers on back woods roads, are you sure 4 days is enough time? How long (hours a day) are you going to ride?
Bronxboy
« Reply #46 on: February 03, 2022, 03:30:38 AM » |
There is never enough time when your 2300 miles from home, but will make the best of it. I am thinking we will need every bit of 14 days to make it a good trip. I want to try and make Glacier Natl Park for a day, then go back home thru all the great roads of S. Dakota?
Pappy!
« Reply #47 on: February 03, 2022, 08:52:52 AM » |
Would love to see some of S. Dakota as well.
Pappy!
« Reply #48 on: February 03, 2022, 08:55:11 AM » |
What days did you set up for at InZane. Arrive on Monday- check out on Thursday? That is what Nick and I discussed.  I put down Friday as a check out day but I can change that while there.
Bronxboy
« Reply #49 on: February 03, 2022, 10:43:46 AM » |
No doubt, we will go home a route that takes us to Glacier Natl Park, down into Beartooth Pass and into SD. We may have a change of plans Pappy. Big Mike is in, and we may head to his cabin in Bryson, then leave from there together and hook up with Keith & Jeff around Memphis.
Dagwood
« Reply #50 on: February 03, 2022, 11:06:29 AM » |
What days did you set up for at InZane. Arrive on Monday- check out on Thursday? That is what Nick and I discussed.  I put down Friday as a check out day but I can change that while there. John and I are currently arriving Monday departing Friday. I’ll be heading back to Michigan by way of Yellowstone, Virginia City, and either Grand Canyon North rim and Route 66 or PCH south of San Francisco (if it’s not on fire or under a rock slide), then Route 66.
Youth and Skill are no Match for Age and Treachery
Farside
Let's get going!
S. GA - N. FL
« Reply #51 on: February 04, 2022, 01:41:22 PM » |
Casey I did the same checking in Monday and out on Friday but discussed w/ the gentleman taking my reservation I might get out Thursday. We can make that decision as it gets closer. I put down Friday as a check out day but I can change that while there. Casey I reserved Monday thru Friday but told the gentleman that took my reservation that I might want to check out on Thursday. He said let them know by the time we check in and it's shouldn't be a problem.
« Last Edit: February 04, 2022, 01:44:22 PM by Farside »
Farside
Pappy!
« Reply #52 on: February 07, 2022, 08:54:59 AM » |
Sounds good! Will stick with that plan and still may switch to a single King sometime between now and then.
MotoRod
My motto .. Buffalo Theory
Clinton TN
« Reply #53 on: February 18, 2022, 11:26:35 AM » |
I'm following SmokinJoe and the gang. Hope to see you guys on the way. When he lets me know his schedule I'll post here.
MotoRod
Bronxboy
« Reply #54 on: February 19, 2022, 03:54:53 AM » |
I am sure we will meet up with others along the way, can't wait...Let's Roll!!
