February 12, 2026, 09:11:43 AM *
Author Topic: Want to add accent Leds.  (Read 1234 times)
6adan
Zip City, Alabama
« on: January 20, 2022, 03:25:54 AM »
  I plan on adding some LEDs and wondering about what gauge wire I should use. I would like to use the smallest wire possible so it would be easier to hide. 2000 CT
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
Jims99
Ormond Beach Fl.
« Reply #1 on: January 20, 2022, 05:29:49 AM »
If your running the pods or tape light, anything small for accent, I use 22ga stranded wire. Small, easy to hide and I can usually pull it through existing harness. LEDs draw very little power. If your using a running light or turn signals, 20-18ga. Spot lights 16ga
May be a little over, but that’s what I’ve been using for years with no issues.
« Last Edit: January 20, 2022, 05:31:22 AM by Jims99/00 » Logged
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Bagger John - #3785
« Reply #2 on: January 21, 2022, 03:09:03 PM »
Spot lights 16ga
10GA with a fuse right at the battery, connected directly to the battery. Power lead (well insulated) is then run into the headlight bucket and a sealed automotive relay (1 input; 2 output terminals) are used to switch power to the spotlights.
Individual feeds from the relay are 12GA. Relay can be triggered via a variety of switching methods. Mine are controlled by a SPDT center-off switch that follows the Lo beam, is Off or allows the spot lights to be On constantly. (Check your state laws. I'm G-T-G everywhere with this setup.)
If using a light bar to mount the spots, run a separate frame ground into the headlight bucket so the steering bearings won't pit due to being part of the ground circuit. I also use 10GA for this run and it's as short as possible.
