February 12, 2026, 11:11:41 AM *
Author Topic: 97 Standard sounds like a little mouse  (Read 1391 times)
lostparrot
Northern IL
« on: January 22, 2022, 01:35:14 AM »
Lil Anne has started squeaking at me.   tickedoff  Situation: From speeds 45mph down to about 15mph, off the throttle, clutch out, I'm hearing a squeak that sounds like a bearing or a belt. When I pull the clutch in, it stops. I can feather the clutch and the squeak will come and go as I engage/disengage the clutch. i have replaced the Timing belts and tensioner pulleys. Any thoughts friends?
« Reply #1 on: January 22, 2022, 05:11:32 AM »
Might need a dab of silicone grease on the clutch push rod down by the slave cylinder.
RonW
Newport Beach
« Reply #2 on: January 22, 2022, 06:56:19 AM »
perhaps inspect the clutch slave.
« Last Edit: January 22, 2022, 07:06:52 AM by RonW » Logged
2000 Valkyrie Tourer
Lionheart763
« Reply #3 on: January 23, 2022, 05:31:28 AM »
I have the same issue at idle on a standard '98 with 40K miles.
