February 11, 2026, 09:58:52 PM *
Author Topic: Eagle lights turn and brake signal kit  (Read 2183 times)
lostparrot
Northern IL
« on: January 22, 2022, 01:37:29 AM »
is anybody using these? just wondering what thoughts are.
https://www.eaglelights.com/products/eagle-lights-sequential-and-strobe-turn-and-brake-lights?_pos=1&_sid=aa5e3796a&_ss=r
Jims99
Ormond Beach Fl.
« Reply #1 on: January 22, 2022, 05:17:35 AM »
Have not tried these. I have used eagle products and have been happy with them so far. First set about 3 years ago and still working fine.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
clanky
« Reply #2 on: January 22, 2022, 06:05:45 AM »
I just added the Eagle lights headlight and passing lights along with the front turn signal yellow/white LED insert into the standard turn signal housing.  Works well.
Lionheart763
« Reply #3 on: January 23, 2022, 05:33:08 AM »
I just did the front white/yellow front turn signals. Love them, flashes too fast so I need the instructions on how to install resistor?
RonW
Newport Beach
« Reply #4 on: January 23, 2022, 09:21:25 AM »
resistors nullify any electricity saving gained from leds which isn't as much an issue with the Valkyrie with its huge alternator but never know when your battery gets weak and you might need every last electron. The usual fix for fast flashing after installing Leds signals is to replace the stock flasher relay with an electronic flasher.
(Leds has less resistance, so more current circulates through the turn signal circuit. This includes the mechanical flasher which the more current heats up that bimetallic strip faster which flexes back and forth at a faster rate, closing and breaking the contacts faster, turning on and off the electricity going to the turn signals at an accelerated rate or faster blinking.)
2000 Valkyrie Tourer
Gondul
VRCC #408
Central Florida
« Reply #5 on: January 23, 2022, 02:04:20 PM »
Don't bother with resistors as stated.
Use an LED flasher...I prefer to get stuff from SuperBrightLEDS
OEM flasher is just in front of the battery box, you can remove the left side cover to gain access.
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/electronic-led-flasher-relays-for-motorcycle/787/842/
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
Lionheart763
« Reply #6 on: October 25, 2022, 04:30:32 AM »
Sweet, didn't like the resistor anyway. Thanks
