February 12, 2026, 11:11:52 AM
carburetor inlet dia.
Topic: carburetor inlet dia. (Read 1356 times)
turtle254
Livingston,Texas
January 22, 2022, 02:17:08 PM »
Can't seem to find what the carburetor inlet size in mm is, where the air box boots connect.
1500 std
Mooskee
Southport NC
Re: carburetor inlet dia.
January 23, 2022, 10:42:10 AM »
The bore is 28mm. If you want the OD, I can go out to the shop and measure one for you.
Valkyrie Carbs and Custom
www.valkyriecarbsandcustom.com
turtle254
Livingston,Texas
January 23, 2022, 11:19:32 AM »
Quote from: Mooskee on January 23, 2022, 10:42:10 AM
Please, just the inlet size from the air box. Looking at maybe changing to cone shaped separate air cleaners. Thanks
Mooskee
Southport NC
January 23, 2022, 12:31:30 PM »
The Funnel Setting Plate, the part that the rubber tube connects to, has a small ridge around it to help secure the rubber tube. That ridge measures 1.878 inches, (4.77 cm) (47.7mm).
turtle254
Livingston,Texas
January 23, 2022, 02:09:54 PM »
Thanks, That's what I needed.
Mooskee
Southport NC
January 23, 2022, 09:52:00 PM »
You are welcome. Post your project and results on here. We will be interested to see how it turns out.
RonW
Newport Beach
Reply #6 on:
January 23, 2022, 10:12:59 PM »
I second that!
2000 Valkyrie Tourer
