Jersey mike
« on: February 02, 2022, 11:46:38 AM » |
https://www.nj.com/coronavirus/2022/02/stop-using-these-2-covid-rapid-tests-fda-warns-they-might-give-false-results.html“ The company, Empowered Diagnostics, is recalling two tests: the CovClear COVID-19 Rapid Antigen Test and the ImmunoPass COVID-19 Neutralizing Antibody Rapid Test.” “The FDA said the recalled tests were not only defective, but they were labeled as if they were approved by the FDA even though they have not been cleared, authorized, or approved by the FDA.” ***In the body of the article is a link for approved tests***
« Last Edit: February 08, 2022, 01:14:29 PM by Jersey mike »
SPOFF
« Reply #1 on: February 08, 2022, 07:40:35 AM » |
« Reply #2 on: February 08, 2022, 07:56:15 AM » |
Me and my family have had around 20 tests between us, all negative...
Never ask a geek 'Why?',just nod your head and slowly back away...  IBA# 22107 VRCC# 7976 VRCCDS# 226 1998 Valkyrie Standard 2008 Gold Wing Taxation is theft. μολὼν λαβέ
« Reply #3 on: February 08, 2022, 07:58:00 AM » |
I've probably had 100 tests since all this began. By your numbers I should have had 80-97 false positives.... I've tested negative every. single. time. Just sayin'
« Reply #4 on: February 08, 2022, 08:13:16 AM » |
Based on its legitimacy alone, this post should be in the PaM board.
« Reply #5 on: February 08, 2022, 08:16:55 AM » |
The original post is a valid general announcement of unauthorized tests. The follow-up comments, not so much.
« Reply #6 on: February 08, 2022, 08:28:32 AM » |
The original post is a valid general announcement of unauthorized tests. The follow-up comments, not so much. The title of this "bombshell" indicates the home tests are all inaccurate. Not the case.
« Last Edit: February 08, 2022, 08:33:26 AM by Valkorado »
Jersey mike
« Reply #7 on: February 08, 2022, 01:15:56 PM » |
The original post is a valid general announcement of unauthorized tests. The follow-up comments, not so much. The title of this "bombshell" indicates the home tests are all inaccurate. Not the case. I changed the subject line. It’s been up there for 6 days and read over 170 times since.
« Last Edit: February 08, 2022, 01:19:00 PM by Jersey mike »
« Reply #8 on: February 08, 2022, 02:07:40 PM » |
« Reply #9 on: February 08, 2022, 02:50:51 PM » |
Anybody wanna swap a home test box for a box of Girl Scout cookies?
« Reply #10 on: February 08, 2022, 03:01:33 PM » |
Yes. Do you have Thin Mints?
« Reply #11 on: February 08, 2022, 03:09:39 PM » |
Yes. Do you have Thin Mints? Wrong way round
