February 12, 2026, 11:10:52 AM *
Author Topic: Custom Tools and Brake Caliper Question  (Read 1565 times)
agrady1995
« on: February 22, 2022, 10:03:31 AM »
Hello all. I am getting pretty good at my rebuilds. Can't get ahold of a metric grease gun fitting at the store because: MERICA'. Does anyone happen to know the thread size/pitch of the bleed screw and possibly the main brake line bolt?
I've made a couple custom tools already and am looking to make some more. In this case it'll be an attachment for my grease gun to pump up the pistons for removal, using one of those two bolts. Additionally, if anyone has any other custom tools they've developed over the years, lets talk about that!
Did first start-up on a valk that's been sitting for 8 years yesterday and she sounds beautiful. Can't wait to do the shocks and rear end and go for a loooonnnnggg "test" ride.
-mike-
Germany
« Reply #1 on: February 22, 2022, 10:52:06 AM »
https://redeye.ecrater.com/p/30933883/brake-pistons-quantity-2-fit-honda
comes with the needed grease gun fitting.
-mike-
da prez
Wilmot Wi
« Reply #2 on: February 22, 2022, 11:55:45 AM »
10mmx1.25 pitch. Can be made from a hose with a banjo end.
                 da prez
« Reply #3 on: February 22, 2022, 12:08:56 PM »
Why not just use the hydraulics to pump the pistons out before disconnecting the brake lines?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: February 22, 2022, 02:47:53 PM »
The pistons don't come out far enough with the disc (or anything) preventing them from coming almost all the way out.
da prez
Wilmot Wi
« Reply #5 on: February 22, 2022, 03:09:37 PM »
  The grease gun method works on the impossible ones.  I made an adapter and reuse the grease just for calipers.  A steel or aluminum spacer with a zerk  (not Serk) fitting installed works very well.
                                   da prez
6adan
Zip City, Alabama
« Reply #6 on: February 22, 2022, 03:43:10 PM »
    This is how I always do it now. If it is a two piston and one wants to come out before the other I let it come almost all the way out and then block it with a piece of wood or anything else I have laying around then I will pump the other one out till I get them both out.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
RonW
Newport Beach
« Reply #7 on: February 22, 2022, 08:59:26 PM »
You might watch this Youtube video https://youtu.be/T6nVwC23JRU?t=80
A forum member mentioned that this type piston puller "are useless on valkyrie calipers."
2000 Valkyrie Tourer
« Reply #8 on: February 22, 2022, 09:10:24 PM »
Grease seems like it would have to work, but be a big mess?
I've found compressed air to work, you gotta be careful not to shoot
the first one that comes loose across the room...
When I just want to push the pistons out far enough to clean them when
installing new pads, I've finally gotten up enough nerve to use hydraulic
pressure. I haven't squirted a piston and a caliper's worth of fluid out
on the ground yet  cooldude ...
Here's some pistons starting to come out with air and blocked by a
board.
agrady1995
« Reply #9 on: February 23, 2022, 08:07:32 AM »
Appriceated but I actually took suggestion from Ross and made my own version of a spacer which fit a grease gun fitting I had in stock today!
agrady1995
« Reply #10 on: February 23, 2022, 08:08:41 AM »
The Hydraulics were not working, and I didn't want to spend too much time doing that on-bike. I had new ones ready to go and swapped them out instead, with a new master.
agrady1995
« Reply #11 on: February 23, 2022, 08:10:08 AM »
You can remove the two bolts holding them on the fork and pump them out, then remove it from the line. Not the solution I wanted, though.
