December 28, 2025, 11:55:27 PM *
Author Topic: Help with Carb Separation .  (Read 1476 times)
Whooray
Idaho State Rep
Kuna, Idaho
« on: February 26, 2022, 11:27:41 AM »
Im having trouble separating #1 from #3 and #2 from #4.
#5 and #6 came off fairly easy.
 There is a lot of corrosion on the joint bolts but they did come out.
Also a lot of corrsion on the 3 way fuel joints.
Corrosion seems to be the cause of them being super stuck.  I dont want to hit or tap on them any harder than I have for fear of breaking something.
Any suggestion or advice from you would be most welcome>
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #1 on: February 26, 2022, 04:12:34 PM »
I think RedEye includes some kind of plastic wedge in his kit. Maybe you could make up some out of some spare plastic or pvc ?
I hadn't thought of doing that, what a great idea.... definitely going to give it a try it !
« Reply #2 on: February 26, 2022, 06:23:38 PM »
I just soaked mine in some WD40 penetrating oil. Laid that area on an old towel and doused it with the oil, left it alone for a couple days while working on something else. Almost came apart by hand after that.
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #3 on: February 26, 2022, 07:42:09 PM »
 cooldude cooldude
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #4 on: February 28, 2022, 03:51:54 PM »
I made a few small wedges from an old vinyl/plastic cutting board..... it worked!
Thanks  a bunch
Ron in Buffalo
Buffalo, NY
« Reply #5 on: March 01, 2022, 12:14:44 PM »
Did mine last year. A lot of pb blaster and a lot of tapping with a brass rod.  When they start to separate they will come apart.
1997 Valkyrie & 2002 BMW F650GS
