December 28, 2025, 11:54:50 PM *
Author Topic: Exhaust gaskets  (Read 1457 times)
Glaserbeam
Southern California
« on: February 28, 2022, 02:03:38 PM »
I've seen two types of exhaust header-to-cylinder gaskets:  copper gaskets with a circular cross-section, and other (aluminum?) with a square cross-section.  Any preference?
Thanks.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: February 28, 2022, 03:38:33 PM »
I've used them both with no detectable difference. They both crush. I thought that the round ones were a bit harder to remove than the others, but it could have been a lack of caffeine in me that one day.
« Reply #2 on: February 28, 2022, 03:42:33 PM »
I like the OEM copper rings and didn't like the fiber ones the one time I tried them...
h13man
Indiana NW Central Flatlands
« Reply #3 on: March 01, 2022, 06:43:52 AM »
Copper variety has been used since Honda hitting the shores in the 60's. Never knew or seen another variant on all metric's brands over the years. I use touch of high heat (red) silicone to assist in mounting.
« Reply #4 on: March 01, 2022, 07:17:03 AM »
And while it is recommended to change gaskets every time the pipes are off, the round copper ones will usually hold a good seal even if the (same) pipes are on and off several times.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: March 07, 2022, 09:38:50 AM »
Ken,
Hope all is well for you out in Southern California.
I've only used copper Honda gaskets, and when using the same exhaust I have not replaced them with no issues of leaks.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
