December 28, 2025, 11:54:40 PM *
Author Topic: Clutch Issue  (Read 1455 times)
MotoBob
« on: March 12, 2022, 05:24:53 PM »
Hello Tech board members,
I have a 2000 Tourer that all of a sudden will not shift out of neutral without stalling.  The bike has 86K miles on it, or maybe it's 186K... I bought it used about 2 years ago, so I suppose it's possible I was mislead.
Checked the clutch fluid, it is clean and the lever pulls with pressure.  I'm thinking the clutch is worn, but just a little surprised it would fail without some type of warning. One day it is shifting without issue, the next it is not.
Can you think of anything else I could do to check the issue before I have to get into a clutch replacement?
Thanks for any feedback.
« Reply #1 on: March 12, 2022, 05:34:49 PM »
Lift your kickstand?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: March 12, 2022, 06:16:56 PM »
What ^^^ said. If it was up, your sidestand or clutch switch may have crapped out. Both are easy to test.
ridingron
Orlando
« Reply #3 on: March 12, 2022, 08:21:32 PM »
Does the Valk have a diode pack in the kickstand circuit?
MotoBob
« Reply #4 on: March 12, 2022, 11:11:35 PM »
[/quote]Oh boy, talk about embarrassment, can't believe I overlooked that one.  Thanks you
