November 12, 2025, 02:51:15 AM *
Author Topic: Interstate pod leak  (Read 1336 times)
VALKMAN
ValkMan
San Jose CA
« on: March 22, 2022, 05:14:27 PM »
Got fluid coming out from the right-side pod. Nothing at the radiator cap, so I am assuming it is coming from the hose underneath. Newer interstate owner, I have never removed the pods before. Can someone give me a quick how to get the pod off?
Valk Man
Valkyrie Rider and Buell Enthusiast
AMA #319125 - http://www.amadirectlink.com/index.asp
The biggest problem with the world is that most people can't get out of the way of their own ASS!
« Reply #1 on: March 22, 2022, 05:24:18 PM »
    only 3 of those allen heads hold it on. in the very front of the pod-and that IS the LONGEST one REMEMBER WHERE it goes. directly on top and sort of 2/3 of the way down towards the bottom. find the pod on a parts fiche for the Honda Interstate. RIDE SAFE.
« Reply #2 on: March 22, 2022, 06:22:49 PM »
Three mount screws (and I think a sidecover-like push pin), the others don't get removed or you are taking it apart unnecessarily.
Many times, a bike laid up for winter will leak a bit of fluid through the hose clamp, until ridden and hose heated up and soaked down, and then not leak again (that season).
« Last Edit: March 22, 2022, 06:26:38 PM by Jess from VA » Logged
SCain
Rio Rancho, NM
« Reply #3 on: March 24, 2022, 05:57:58 AM »
If you are on the right side of the bike, remove the 3 screws like mentioned above, with your left hand pull on the back of the pod straight out to remove the boss from the grommet, then with the same hand lift up on the back of the pod to get it up and over the mount. Once its up and over that mount it should come straight off.
Steve
